Old 03-11-2007, 05:40 AM
K9sH3's Avatar
K9sH3 K9sH3 is offline
Default Who has pics of..
I know I have seen a pic of a Red top or a Yellow top installed, I bought a yellow top and it just doesn't sit exactly snug. How did you modify, to make it work?
Old 03-12-2007, 04:22 PM
Desert Dan's Avatar
Default Re: Who has pics of..
I have a red top. No pics though
Did your new battery come with the clip the fits the base of the Optima that allows you to bolt in it tight?
The cover wouldn't fit over teh Optima but this can be fixed by trimming/ the holes for the termials
The nylon web strap was too loose on mine so it is being only being held in by the base
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 03-12-2007, 08:23 PM
K9sH3's Avatar
No, dang it, I didn't get any clips. And the strap is a lil loose. I was wanting to cut the new holes, but wasn't sure if the thing would work.
Thanks Dan, For the help.
Old 03-13-2007, 09:34 AM
Crash ?'s Avatar
Crash ? Crash ? is offline
Haven't seen one, but if the straps are loose, you should be able to set the battery on a block of wood under it to lift it up where the strap can be pulled down tight..
Rob
