Old 03-12-2007, 05:21 PM
orlasttoy's Avatar
orlasttoy orlasttoy is offline
orlasttoy is off the scale
Default air compressor is killing my battery!
batt was totally dead the other night, after jumping it, noticed the air compressor running for a while...
i want to pull the fuse, but there are multiples:
in the manual, VSES/ECAS is labeled: (ECAS) Electronically Controlled Air Suspension (NO mention of what VSES is)
HVAC/ECAS is labeled Climate Control Controller/Electronically Controlled Air Suspension Module
my question is, if i yank the VSES/ECAS relay, will i be disabling something i need? (VSES)
oh..there is also a fuse on the inside panel labeled "4WD" which, according to the manual, is Four Wheel Drive Switch, Electronically Controlled Air Suspension Switch/Module
and advice on what to yank will be appreciated
thanks!
