Old 03-12-2007, 11:27 PM
enfuego02 enfuego02 is offline
enfuego02 is off the scale
Default Instrument Panel question
Help me!!!
I just bought a brand new Instrument panel cluster for my H3. I installed it but it did not transfer any of my odometer mileage over. Is there anything else i have to do to get the old information onto the new cluster. I thought that all you had to do was plug it in and it will transfer everything over.
Thanks!!!
Old 03-13-2007, 11:01 PM
pdsq99f4 pdsq99f4 is offline
Default Re: Instrument Panel question
Why did you need a new instrument pannel cluster? You need to take it to the dealership and they need to do a relearn to get it to work properly. Sorry there is no other way.
Old 03-15-2007, 12:15 AM
Did you drive it yet? The odometer will read zero miles after the instrument panel cluster (IPC) is replaced. The body control module (BCM) stores the mileage information for the odometer. The vehicle will have to be driven for the BCM to send out a mileage update to the IPC. The IPC should then display the current mileage.
Old 03-17-2007, 10:33 PM
thanks f5fstop....I originally just plugged it in and didn't drive it.
thanks again....
