Old 03-13-2007, 04:31 AM
sogdoc1 sogdoc1 is offline
sogdoc1 is off the scale
Default Rear Wiper Washer?
I have been having trouble with the washer spray on the rear wiper. Had it in the shop two weeks ago and worked for 1 week and then started only spraying on the bottom third again. Anyone else having this problem. Like I said, had the shop fix it once and it happened again. I have an hour drive to the dealer and would like to know if anyone has an idea on the fix before I get there. They obviously didn't fix it right the first time. Thanks for any help.
Old 03-13-2007, 05:08 AM
SHYANNE SHYANNE is offline
SHYANNE is on a distinguished road
Default Re: Rear Wiper Washer?
I never have thought about it till now. where is the fill bottle to fill it up with wiper fluid ?
Old 03-13-2007, 05:09 AM
K9sH3's Avatar
K9sH3 K9sH3 is offline
There was a recall on the rear wiper, Not sure what it was for though.
Old 03-13-2007, 06:05 AM
So how and where do you fill it up at ? location ?
Old 03-13-2007, 02:50 PM
fourfourto's Avatar
Mine originaly was working fine and they replaced it .I got a letter in the mail.
The rear wiper shares the tank with the front,there is no seperate tank.
Old 03-13-2007, 03:37 PM
Ok thanks good to know that i didnt know where it was till now.
Old 03-13-2007, 05:11 PM
Mine crapped out after heavy use in snow country (at Lake Tahoe), they replaced it and so far, so good.
Old 03-13-2007, 05:14 PM
never use cause your can't see crap out of the rear anyway.
Old 03-13-2007, 05:18 PM
Aphextwinop's Avatar
Aphextwinop Aphextwinop is offline
Aphextwinop is off the scale
Had mine replaced about a month ago.
06 Birch White, Adventure Package, Monsoon Stereo, A little bling here and there , but not too much.
Old 03-13-2007, 05:54 PM
yat74's Avatar
yat74 yat74 is offline
yat74 is an unknown quantity at this point
Had mine replaced during the intitial recall and the pump still is a piece of crap. I think that because it shares the same resevior with the front wipers it can't pump the fluid efficiently enoough to be able to spray the entire rear window. Plus, the resevior in the front is not in the ideal spot for the rear pump as the resevior is below the level of the pump and all the way in the back making fluid transfer difficult. Anyone have any bright ideas as to how we can remedy this? Fabing some type of nozzle to fit over the spray tip to concentrate the stream of washer fluid...I don't know....or GM puts in a even more powerful pump and a wiper that goes more than 45 degrees.
The Goat
Old 03-13-2007, 06:26 PM
HummerHippy's Avatar
Dont use mine much 'cuz you cant see anything out of the back from the little cleared area.
I think the recall was for the rear wiper motor.
I was in Tahoe 2 weeks ago, just in time for a 5 feet dumping over the weekend! Snowboarding was awesome that whole week!!!!!
29-Jul-2008
Old 03-13-2007, 08:28 PM
Yea, visibility out the back is limited. It's easier to keep the little dime sized glass on my Hitchcam clean so I can see out the back.
marin8703's Avatar
i dont really have any prolems with mine. It sprays the whole length of its motion, and i find it enought to be able to see out the back. I still cant figure out why they would make it go only 2/3 of the way. sorry im not of any help thou.
Old 03-13-2007, 10:11 PM
im embarrased to use it that lil squeegie spot it leaves is tiny
Old 03-13-2007, 10:37 PM
fourfourto's Avatar
that lens gets dirty,How about we design a small wiper blade for it.
It wouldnt be hard to add a squirter above it.
Old 03-13-2007, 11:42 PM
That would be cool, like the little squirter/washers on my Litronic headlights on my Porsche!
