Old 03-14-2007, 01:19 AM
Beonly1's Avatar
Beonly1 Beonly1 is offline
Beonly1 is on a distinguished road
Default Hummer redo on Overhalin'
Don't know if you guys have access, but The learning channel is doing a redo of a Humvee used in Iraq . Apparently it is a repeat, but I haven't seen it. Its on right now 7-8 pm central. check it out
Beonly1
?If you always put limit on everything you do, physical or anything else. It will spread into your work and into your life. There are no limits. There are only plateaus, and you must not stay there, you must go beyond them.?
?If you make an ass out of yourself, there will always be someone to ride you?
-Bruce Lee
