Old 03-18-2007, 03:43 AM
Efrain's Avatar
Efrain Efrain is offline
Efrain is off the scale
Default CD not responding
Hello everyone. I have this situation: One day I got inside my H2 and noticed that the clock had reset by itself. I didn't give it much thought, but I later found out that my cd does not respond at all, my radio and tape player work, but not the cd. I've noticed the clock resetting a couple of times again after that. any suggestions or comments?
Old 03-18-2007, 03:09 PM
mikejr's Avatar
mikejr mikejr is offline
Default Re: CD not responding
have you tried searching the forum for the same issue?
I've never had that happen in my H2, but i recall in my 03 avalanche the 6 CD radio would just stop working and once i shut off the truck and restarted it then it worked again. only did this a few times thankfully.
Seems that i read something on here about this problem before.
2009 H2 Silver Ice LE
Old 03-18-2007, 09:22 PM
For the clock reset, check your battery cables to make sure they are both good and tight. The clock resetting is common with a loose cable; negative and/or positive. Non-working CD? Could just be a coincidence that it is broken or else the radio is starting to break.
Old 03-19-2007, 04:10 AM
Efrain's Avatar
Thanks guys for your responses.
