03-21-2007, 05:52 PM
OEM Steps Bolts
I need OEM Tubular Step Bolts...does anyone know type/size? Over $100 from the dealer! Thanks!
Greg
03-21-2007, 06:45 PM
Re: OEM Steps Bolts
your kidding bro, so the steps make it ok? Let me ask around. should be just a few bucks at a pep boys or checker.
03-21-2007, 08:09 PM
Re: OEM Steps Bolts
They should be here Friday...can't wait! The GM Dealer here said about $100, the Hummer Dealer about 2 hours away said they cannot get them unless I order the steps. I can figure out what they are...just thought there may be some info out there on them. Are the nuts permanently mounted on the frame, so I just need bolts? Thanks!
Greg
03-21-2007, 08:39 PM
Re: OEM Steps Bolts
If your talking about tubular side steps they should be 10mmX25mmX1.5T. If I remember correctly from installing rock rails. The rock rails used the same location fasteners as the OEM tubular side steps.
03-22-2007, 12:17 PM
Re: OEM Steps Bolts
You can buy the same bolts from Chevrolet cheaper.
The bolts that came with my Rocky Road rails were the wrong ones. The Chevy dealer is much closer than the Hummer dealer so I went there first, problem solved for half the price - for the same bolts.
Might just be the individual dealer markup. The Hummer dealership here charges top-dollar on everything.
03-22-2007, 12:52 PM
Re: OEM Steps Bolts
Greg
$100????? Are you joking? Hardware store will only set you back about $8
03-22-2007, 02:53 PM
Re: OEM Steps Bolts
I am definately going to my local True Value hardware store. Thanks for the info.
Greg
03-22-2007, 10:44 PM
Re: OEM Steps Bolts
Greg
Make sure you get at least Grade 5 bolts...
