03-31-2007, 01:25 AM
Magnuson Supercharger Purchased Today
66' VETTE STINGRAY
07' Z06
03-31-2007, 04:35 AM
Re: Magnuson Supercharger Purchased Today
Enjoy it! I'm sure it'll be a blast!
04-01-2007, 01:21 AM
Congrats  It's also on my list of things to get.
2005 H2 SUV (Yellow)
2003 Vert Supercharged
04-01-2007, 01:39 AM
04-01-2007, 01:46 AM
Does anyone remember who put the "Supercharged" range rover logo next to their h2 door badges after installing their charger?
66' VETTE STINGRAY
07' Z06
04-01-2007, 02:00 AM
here it is
http://www.elcovaforums.com/forums/s...ad.php?t=25402
Old Chinese Proverb "Man who walk through airport turnstile sideways going to Bangkok"
04-02-2007, 12:56 PM
On tranny, diffs, and engine drop all fluids as well as filters where it applies. Go with Royal Purple synthetic. Will make a difference and tranny may run for no telling how long. I only know the fact of Royal Purple so not saying any other fluid would not achieve this but, it was proven on Horespower TV that making all the changes to Royal Purple got them I think it was 8 more HP and I forget the torque.
On tranny firm up the shift as much as You can without it being to uncomfortable. This will be increasing line pressure thus reducing band slippage as much as can be done without a full tranny upgrade. This will really increase life of tranny, even stock. You could also change to a Vette servo and a few other things on tranny which I'm sure Your shop will be aware of.
Would help to go to a 160 degree T-Stat since they will be removing some things in the area anyway where it is only about an hour tops change out anyway. Heat is the main enemy to increased boost and detonation. Ask installers to do a throttle body heater hose by-pass. In the lower half of the USA this is not really needed as it just heats up throttle body temp raising fuel temp to aid in cold weather starts. I have done this mod to my H2 and first time on my 99 Silverado.
An electric fan conversion would be helpful sometime down the road. An OEM electric fan conversion can be used from I think the 3/4 ton GM trucks and also can be wired into PCM so that it will turn off and on by temp sensor using the factory programing. The function is already there for H2 just not used. You just have to have whoever tunes the rig turn that on. You do have to make some tranny line relocation or alteration that is. Nothing that is a big deal. You will need a wiring harness from Allen Nelson at nelsonperformance.com in Texas to run the dual fan setup.
Get boost and air fuel ratio gages just to be on the safe side and learn to check them as You do temp, oil, and other gages. You should not be romping it all the time once the new wears off. But, enjoy allot at first.
I have done all these things to my H2 and more so I feel comfortable in recomending these things. You do not have to do all at once but, standard rule i have lived by and learned is that once the mechanic is there and has somethings apart it does not cost much more to go ahead and get some other things done while he is working in the area.
I hope this has been helpful and if i can help further let me know with a PM and I will try to have an answer or find it out through connections if i do not know already. I'm sure i may have not covered some things but, hey I have been quite sick after thinking things were getting better so I could over look a good suggestion. I know i'm not wrong with what i mentioned here but, may have left out a little trick or two.
Congrats and You will enjoy the change if done right. In Dragon and my custom process we left all branding off for a cleaner show look but now with the supercharger badge to add on from range rover i wish now we had left the H2 on the sides. Perhaps we can come up with something in a painted on ghost spray effect like you can do with flames. Put it on each side of the reverse cowl hood scoop also i think would be nice.
TAz
04-02-2007, 05:30 PM
I'm a firm believer in good 4-core radiators when you've upped the HP. Go for the best, and you'll never regret it.
1968 Mustang GT convertible
04-03-2007, 10:04 AM
Captain I do not disagree with You at all on radiator as cooling is a priority with more boost and HP. My experience with all the HP etc I run with my H2 has not been a problem yet unless as I lean it out more experimenting it pops up. I will then figure out what I need to do. The factory RAD does great with a dual electric fan setup. It did fine even before actually without the twin fans. My H2 is not a daily driver it is a show rig and I'm able to slowly push boost and HP so that it will leave me the luxury of tweaking and leaving it not having to adjust things back for regular street drivability.
You know as You mentioned I will have to look at the RAD more as I push the HP on up to the 750HP or as close to 1000HP as I can get it and I raise the boost on towards 16, 18 or 20lbs. I will have the water/methanol inj. going at WOT and co2 spray on the SC aftercooler radiator. It will just take tinkering.
Just going to 5lbs. of boost on my H2 was a nonevent except for the power and speed. I do have gauges to watch the situation and even ran 87 octane because tuning was so rich I had no detonation. Reason for trying the 87 was because it is more volatile than 93 and you get more power out of it than 93. Running the higher octane is to prevent detonation and help hold temps down. I had gauges before the supercharger was added and the tuner I used then was still leaving the rig running so rich it was a joke. I knew I was not going to have temp problems tweaking it more with SC. Even after adding the SC with the kit tuner it still left it real rich. HPTUNERS software will let me tweak the 5lbs. boost allot leaner first with wideband sensors before I go up in boost and I can watch the temps as I go.
You know crawling before you walk then walk before you run.
TAZ
04-21-2007, 09:22 AM
Its done! Headers, cams, and Magna Charger Super Charger! I'll let everyone know what I think and post pics tomorrow. I already think Im changing the heads though...
66' VETTE STINGRAY
07' Z06
04-21-2007, 04:54 PM
04-21-2007, 05:08 PM
I used this one:
As for cooling, I never had any problems with the stock radiator, but I know several that did. I had the stock fan on, switched to the electric fans until I shredded them in some water, then went back to stock.
If you plan on wheeling the truck in deep water with electric fans, make sure you have a kill switch for the fans so you can turn them off when blasting through the water.
160* t-stat is mandatory.
http://griffinrad.com/
04-22-2007, 02:23 AM
Going to post the pics of the charger asap, things have been crazy today! I have a question though.. Does anyone know what the variance should be on the air/fuel ratio gauge. Mine reads something like 14.6 I believe and it stays that way most of the time. What number should I look for if something is wrong? Also, is there a break in period for the charger? MTI was closed
66' VETTE STINGRAY
07' Z06
