Old 04-05-2007, 09:31 PM
JamesT's Avatar
JamesT JamesT is offline
Default Toyo M/T's Defects
If you have Toyo M/T's go look at them. Mine have about 35K on them and they began cracking (dry rot) on the surface between the treads. My local shop is swapping them out but Toyo apparently gave them fits about doing it. These tires are rarely used....errrrrr....never used off road and there is no excuse for this to happen. Nobody at Toyo is stepping up to the plate to say wheather there is a 'known issue" but I find it hard to believe that mine are the only ones doing this. Anyone else?
People Who Annoy Me...NAGGERS
Old 04-06-2007, 02:52 AM
ChrisGTA ChrisGTA is offline
ChrisGTA is on a distinguished road
Default Re: Toyo M/T's Defects
How old are the tires, in years not miles? My guess is 3-4 years. There is no such thing as "dry rot" what you are experiencing is UV damage. Usually this will show up when tires are a few years old. It looks to me like your dealer went above and beyond for you.
Old 04-06-2007, 03:01 AM
mikejr's Avatar
mikejr mikejr is offline
i tend to agree....having spent many years in the rubber roofing business prior to being in real estate.....what you are seeing definately looks like UV damage that we used to see in the rubber membrane on the roof. Is the damage around the entire circumference of the tire?
2009 H2 Silver Ice LE
Old 04-06-2007, 05:18 AM
dochummer's Avatar
"never used off road and there is no excuse for this to happen."
I agree.... get your butt off-road!!!
'03 H2
Old 04-06-2007, 02:58 PM
JamesT's Avatar
It is on all 4 tires and on the entire circumfrence.
Old 04-06-2007, 06:06 PM
Big Z Big Z is offline
Here's a couple shots, (today) of some 5yr/50K+ tires.
Old 04-06-2007, 06:07 PM
2
Old 04-06-2007, 06:13 PM
Desert Dan's Avatar
those cracks don't appear to be dangerous to me
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 04-06-2007, 06:25 PM
Had 1/2 dozen of these checked out--K's--ago..Most are 1"-2 " long @ the tread base--just rotated 1K ago & there still rollin 80!..and taking a beating!
Old 04-06-2007, 07:00 PM
Desert Dan's Avatar
Big Z
I had some MT BFG's siped and it seemed to help in the rain on asphalt of cement roads.
Does it help on the Toyos?
Desert Dan
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 04-07-2007, 12:32 AM
Originally Posted by Desert Dan
Big Z
EVERY tire I Buy gets Siped!! Tire life is extended, grip better is All conditions, and they run COOLER!...Big plus in tire life, in these HOT Ass Desert States!
Old 04-07-2007, 02:39 AM
HEY!!! Those look like my tires.
Old 04-07-2007, 05:07 PM
You still got um!?...Figured youd be on your second or third set by now!
