Old 04-06-2007, 06:46 PM
TOPLINE's Avatar
TOPLINE TOPLINE is offline
TOPLINE is on a distinguished road
Default DOOR PANNEL HELP
can anyone tell me if there is a easy way or the correct way to remove the inner door pannels on all four doors without doing any damage as i am going to put my buckets on this weekend and dont want to snap or break anything while doing it
CHEERS
Old 04-08-2007, 11:55 AM
TOPLINE's Avatar
Default Re: DOOR PANNEL HELP
some one must have a clue on how to take off the door pannels does the handle and switches all come off together or how do i do it without breaking anything please help its hard enough to get help over here never mind a door pannel if i snap it HELP HELP pic would be great
CHEERS
Old 04-08-2007, 03:07 PM
lonePalm's Avatar
lonePalm lonePalm is offline
lonePalm is on a distinguished road
yes the door switches do have to come out, use a small flat head to pry up on the switches, just be very careful. also you need to take the bucket off inside door that helps hold the door panel on, once you do that place a large flathead screwdriver under the bottom corner of any door panel and pry gently, you will here a noise as if it is breaking but its not there are plastic door fasteners that you'll hear. after you get an opening large enough to fit your hands in as you pull the panel out work your awy around the whole paneland once you have done that slide the door panel up towards the top of the door and it should slide right off......also be aware of thedoor light dont forget to disconnect it also. Good Luck!
Drive fast and Beep the horn!
Old 04-09-2007, 06:15 PM
TOPLINE's Avatar
thanks very much for that lonepalm very helpfull had the buckets for a while now but never got round to putting them on now the summer is nearly here i can put them on and bling up my baby cheers again
CHEERS
