Old 04-06-2007, 08:30 PM
fourfourto's Avatar
Default Second replacement of roof rails
The left (drivers side) had to be replaced again,nice tight fit
I thought they changed the plastic on the ones that were originaly replaced.
I had both sides and the side windshild trim last year.
I guess it cant take the cold to hot or ice gets in there and CRACK
Had no problem fixed under warranty. In and out less then 1 hour
While at the dealer.
I didnt see any 07's with the new door switches ?
I did see the rear licence plate with a bottom suportI didnt get a price from parts though.
The salesman said the V8 would be out in July
The service rep (nice guy) was dumbfounded by my silicone on the brake pad (temp)fix,I told them the brakes caused a vibration that rattled the ebrake assy and caused the noise I was getting,He didnt understand a vibration in the pads making a noise ,he said brakes dont vibrate . I told him I temporaraly tied off the ebrake lever and noise was gone,lube or spray seems to work for a while.
I think slightly thicker shims with the lube will solve it permently,I think I have a little noise back after 5,000 miles.I will add thicker shims at next tire rotation and see how long that lasts.
