Old 04-07-2007, 03:26 PM
blitzz58 blitzz58 is offline
blitzz58 is on a distinguished road
Default cummins conversion
is the conversion by avalanche engineering worth 30 g and does it make a huge difference
Old 04-09-2007, 03:05 AM
Ground hawg's Avatar
Ground hawg Ground hawg is offline
Ground hawg is an unknown quantity at this point
Default Re: cummins conversion
Depends on what it gives ya. if it saves that much in diesel gives you that much mor HP and fbt then maybe yes. but I bet you could custom build the GM6.5td to do exactly the same or near enough at a fraction of the cost
Old 04-10-2007, 03:18 PM
what upgrades to choose from, which components will make the biggest impact, for the money. just not familar with 6.5 any ideas, can the 6.5 run close to cummins and duramax
Old 04-12-2007, 03:20 AM
Have a look at some of the performance upgrades on this link.
http://www.ssdieselsupply.com/index.html?PHPSESSID=f9767601e01003f858c69c2828aa3 128
there are loads of othere sites. it all depends how much you can do your self and how much you want to spend.
Old 04-27-2007, 06:42 PM
ssgharkness020147's Avatar
Ok, so I'm a bit late on this subject... But, If you want to buil REAL power out of a 6.5 you really need to get one built up, Peninsular Diesel and Diesel Depot (which is who I would use), are two names that are worth looking at. If you want some contact info for them let me know. As far as the numbers go, you can get a 6.5 to about 300 HP and somewhere in the ballpark of 600 lb/tq (probably about 550), without the engine wanting to explode.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
