Old 09-05-2003, 04:12 PM
Hum2's Avatar
Hum2 Hum2 is offline
Hum2 is off the scale
I can't seem to find the thread on the Fram Sure Drain for the H2. The auto places carry some here in Omaha, but they can't tell for sure, by either computer/catalog, if it applys to the H2 or not.
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Hum2's Avatar
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 09-05-2003, 06:52 PM
Grendel Grendel is offline
Grendel is off the scale
Their website doesn't list a part number for the H2 or any other Chevy truck with the 6.0. They might not have one available yet. I would try to call Fram and verify this though.
2003 Pewter H2
2003 Pewter H2
Old 09-08-2003, 10:39 AM
Hum2's Avatar
FYI:
Just got an e-mail from Honeywell/Fram....They do not have a sure drain for the H2 Hummer yet.
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 09-08-2003, 11:18 AM
Hum2's Avatar
FYI:
Here is that e-mail.
Ric
Thank you for your e-mail regarding a Fram Sure Drain plug for your 2003
Hummer H2, V8-6.0L. We welcome the opportunity
to be of service.
According to our data, we don't have a recommended Sure Drain plug for
the 2003 Hummer H2 with the V8-6.0L engine. We
are currently working on updating product information for those vehicles
we do not have yet available.
If you choose to determine the adaptability of the Fram Sure Drain to
your 2003 H2, you will need to consider the
following criteria. You will need to determine the thread size and
pitch of your oil drain plug. You will also need to
determine if the copper drain plug gasket that is provided with the Sure
Drain oil plug will provide an appropriate seal
against the oil pan. You will also need to verify that the Sure Drain
oil drain plug has appropriate clearance and does
not cause any functional/operational interference.
The Fram Sure Drain is currently available in 5 sizes. Listed below are
the part numbers and corresponding thread
sizes:
SD1 = 1/2" X 20
SD2 = 14mm X 1.5
SD3 = 12mm X 1.25
SD4 = 12mm X 1.75
SD5 = 18mm X 1.5
Thank you for choosing Fram Products.
Cordially,
Joslyn Summers
Catalog/Technical Service Representative
Catalog/Technical Service Department
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 12-04-2003, 05:53 PM
H2-USA's Avatar
H2-USA H2-USA is offline
H2-USA is an unknown quantity at this point
Fram SureDrain SD-4 is now available
Here is the recent response I received. I purchased 1 at a Kragen Auto Parts last night, under $20.00.
November 17, 2003
Thank you for the e-mail regarding a Fram SureDrain oil drain plug for your 2003 Hummer H2 6.0L engine. We welcome the opportunity to be of service.
The SD4 is the Fram SureDrain oil drain plug for the 2003 Hummer H2 6.0L engine.
Thank you for choosing Fram products.
Cordially,
Scott Jacobs
Old 12-05-2003, 11:04 PM
Hum2's Avatar
Thanks H2-USA....I did find out that the SD-4 worked on an H2 about 2 months ago...just forgot to get back to the FORUM on that. Sorry!
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
