Old 04-12-2007, 04:32 AM
finbox finbox is offline
finbox is an unknown quantity at this point
Default Tranny Hesitation or RPM "hunting" ?
Hey guys,
My 2004 is starting to hunt/hesitated while going down the road at around 35-45 mph. NO load, dead flat ground.
I have check my transmission fluid it looks good. no mixing with radiator fluid...what year was that a problem?
I don't know if it's the tranny or the engine. It is very faint, almost like when your almost out of gas on a motorcycle "if you have a bike you know what I mean".
It will get up and go when I floor it and shift normal.
I have 45,000 miles on her
I have tried to do a search but tranny, trans, etc come up with too much info to look at.
Thanks for the replies,
finbox
Old 04-12-2007, 04:39 AM
Tex_h2's Avatar
Tex_h2 Tex_h2 is offline
Default Re: Tranny Hesitation or RPM "hunting" ?
Originally Posted by finbox
Hey guys,
finbox
I had a similar problem with my last truck........it wasn't the tranny...but rather some back pressure issue with the muffler.
Old 04-13-2007, 02:04 AM
mikejr's Avatar
mikejr mikejr is offline
does it hunt if you push the tow haul switch or if you put the tranny in 3 instead of D? GM's are known for hunting and every GM truck that i've owned tends to hunt a bit.
2009 H2 Silver Ice LE
Old 04-14-2007, 05:00 PM
I will give that a try
