Old 04-14-2007, 10:52 PM
hummer_metal's Avatar
hummer_metal hummer_metal is offline
Location: PA, Back in the deep mountains, away from stupid people!!
hummer_metal is on a distinguished road
Default Wiring Question for PIAA lights
Where can I put the cord through the firewall?
On the drivers side I found a group of wires going through a rubber boot. but there must be a half roll of tape around it.
Am I at the correct location?
black 06 H3, tow package, monsoon, no bling bling, all the off road stuff... I even have the off road stuff that your mother warned you about.
veg?e?tar?i?an (vĕj'ĭ-t?r'ē-ən): Old Indian word for "Poor Hunter"
http://themetalpeddler.com
Old 04-15-2007, 09:04 PM
Default Re: Wiring Question for PIAA lights
You can drill a new hole. depends on what gauge you are pulling. Use a punch once you have picked the spot on the firewall. Drill it out. Usually 3/8" will do. When all is secured use some silicone to seal off the opening to wire difference. That seal will reduce the likelyhood of shorts and also keep the sounds and odors where they belong.
Just verify both sides of the firewall b4 you start drilling. However there is room to do it safely. Fear not!
Old 04-16-2007, 11:43 PM
Thanks, I just didn't wanna do the drill thingy is all. But is the best way...
Old 04-17-2007, 12:04 AM
Use RTV to prevent water coming in. Also make sure to use some type of rubber gromit where it comes through the firewall.
Old 04-17-2007, 12:54 AM
very good advice...Make sure to use a grommet. That firewall will be as sharp as a razor and will cut the wire in no time. The grommet protects the wire from the metal, while the RTV keeps your feet dry. Also, make sure that you install the fuse as close to the power source as possible. That way if the wire shorts, it blows the fuse at the power source.
Old 04-17-2007, 02:11 AM
marin8703's Avatar
May be a stupid question but whats an RTV?
Old 04-17-2007, 03:37 AM
fourfourto's Avatar
Any type of silicone that get hard at room temperature.
RTV = Room Temperature Vulcanizing
Old 04-17-2007, 04:09 AM
K9sH3's Avatar
K9sH3 K9sH3 is offline
I want a pair of boxers that say that on it...
Old 04-17-2007, 04:11 AM
K9sH3's Avatar
Also, Make sure that you don't have it running hot at all times. It could drain your battery. I learned the hard way.
Old 04-17-2007, 05:21 AM
I've used RTV silicone for years and never knew what the letters stood for . Just new it was good around automotive applications. Went to the garage and read all the info on box of silicone doesn't say --just RTV silicone. Thanks for the info. The Rebel
H2 REBEL lennyrebel
Old 04-17-2007, 10:48 AM
I sure would hope there is a relay involved somewhere in the lights' circuitry. In addition, hot wire is no problem. I have my switch input for the relay direct off the battery, as well as the main power to the lights. You just have to remember to turn the darn things off.
Old 04-17-2007, 06:35 PM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
And if you are using hard plastic covers, remember to take them off BEFORE turning on the lights
Old 04-17-2007, 06:36 PM
evldave's Avatar
Hmmm, you have access to the internet, couldn't you have just googled it instead of going all the way to the garage and reading all the info on the box??
Old 04-17-2007, 11:23 PM
