Old 04-18-2007, 02:18 AM
Lucky1 Lucky1 is offline
Lucky1 is off the scale
Default instrument cluster lights gone out
My instrument cluster lights (speedometer) went out behind my speedometer. I was wondering if they are replacable or do you have to send them off to be repaired. Only two bulbs are blown or loose and the rest work fine. Has anyone else had this problem before. I have a 2003 H2 with 11,000 miles. Please help thanks .
Pimpin 8 E Z but somebodys gotta do it .
Old 04-19-2007, 02:06 AM
Default Re: instrument cluster lights gone out
Someone please help.
Old 04-19-2007, 02:43 AM
orlasttoy's Avatar
orlasttoy orlasttoy is offline
orlasttoy is off the scale
wow..an '03 w/ only 11k miles?!?!?
sorry...i havent had much luck w/ dash light questions here either
Old 04-20-2007, 05:36 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Needs to be sent out for repair, If your gonna send it out and its the original cluster may as well get A replacement cluster as you will likely end up with speedo and/or other gauge problems. Not too expensive for an exchange unit and it will avoid A future repair.
Old 04-20-2007, 01:11 PM
they arent to hard to repair. i just did mine.replaced a motor..but humtech is right you may have other future problems come up with the motors in their. so you might wanta look into a trade. their are around 200 or so to get a rebuilt one. good luck
Old 04-21-2007, 10:51 AM
Thanks for the info. I think I will pull it out and try to figure it out and if I can't fix it I'll replace it. Thanks again.
