Old 04-24-2007, 04:15 AM
Default Thoughts about intercooler and oil cooler relocationing???
I installed the supercharger this last weekend. The aluminum radiator installed has transmission cooler lines but no oil cooler lines in it.
The small intercooler mounted immediately behind the grille on the hood is now going to be a transmission cooler.
I purchased a larger intercooler and am going to install where the transmission cooler is.
That leaves an oil cooler needed. Still not sure where to mount it. A few thoughts are below where the factory transmission cooler mounts or a vertical cooler inbetween the cooling fans on the back of the radiator.
Suggestions? Discuss.
Thanks,
Mark
