Old 04-25-2007, 02:25 PM
nmu98 nmu98 is offline
nmu98 is on a distinguished road
Default removing the cab light..... for sirius wire
How do the center yellow lights remove from the cab. I want to run my sirius ant though there... I dont think the wire is long enought to make it to the rear...
Old 04-25-2007, 03:23 PM
Default Re: removing the cab light..... for sirius wire
it will make it to the rear just barely.. but i know the 2 side top markers just have one screw in them... the center ones im not sure about.. you could run it though a side light.
Old 04-25-2007, 03:50 PM
YOur better off using the side markers. Those centers are more likely to leak on you. I ran mine though the PS SD marker. I poked a hole through that boot and put a small dot of RTV. No Leaks. Oh, and I mounted mine on the leading edge of the windshield. Even with the Gobi Rack up there, I have ZERO interference.
Old 04-26-2007, 12:42 AM
Thanks guys, I am going to install this tomarrow...
