PREDENTED H3 REAR DOORS BY GM
Picked up my '07 H3 that replaced my gremlin infested '06 ... My son
immediately noticed the RIGHT rear door had dent in the just above the crease ... I found a similar dent in the left rear door
I happened to find the same dents in the same area on my wife's '06 ...
Contacted a professional dent remover who has been in the business for
over 20 years ... He got most of the dent out, but in our conversation he
told me that it looked to him this was from the outter skin being pressed
to the inner door and it would only have happened at the factory ...
Now my question to GM is what are they going to do about this?
You just might want to check your rear doors also
FOOTNOTE:
I was at the Hummer Dealer in Milwaukee last night for
service on my wife's '06 H3, which also has the dents in the rear doors.
EVERY H3 I checked had the dents, some worse than others
If you want to check: Stand infront of your H3 to either corner
take one side step to the left or right and look toward the front
seam of the door just above the crease ... It's there !!!
Now if enough owners complain to GM there will be a resolution
If, not .... The shoddy workmanship will continue ... remember
the brake recall GM is now doing on Chevy pickup trucks covering
10 years worth of production ?
Let's not be a silent majority ... Complain to your dealer & contact GM
Both my '06 & '07 are headed to the dealer's bodyshop for replair
under warranty ... Having done a bit of investigation into this matter
the dealerships are aware of it, but are told by GM not to say or do
anything until the customers complains
_________________
If, you wait by the river long enough,
You will see the bodies of your enemies float by
