04-30-2007, 10:31 PM
Heated Seat Problem
my '07 has just developed what i'm sure is a minor problem, but i was wondering whether anyone else has experienced it. the passenger side heated seat stays on even when the toggle switch is in the off position. i've tried switching it to high, low, off etc etc but it wont stay off until the engine is turned off. i guess i'll have to take it in with a few other minor issues i have since i got it in early december. but does anyone have an ideas? also, what's the best (as opposed to manual recommended) tire pressure. i have the lux with auto, and no luggage rack. live in lower new england, so winter is winter and summer is summer. TIA.
04-30-2007, 11:06 PM
Re: Heated Seat Problem
I had the same problem with my 06 H3 on the drivers side last summer. They had to replace the switch.
05-01-2007, 02:05 AM
I have an 06 LUX, auto, no rack and I run 38psi cold...the tires are running smoothe and even... you fell a little bump but the wear pattern is perfect...
05-01-2007, 02:42 AM
irun almost 40 and get better mpg
05-01-2007, 03:13 AM
This is the optional "mother-in-law riding shotgun discourager". Your dealer should be able to disable it for you.
