Old 05-03-2007, 04:19 PM
yat74's Avatar
yat74 yat74 is offline
yat74 is an unknown quantity at this point
Default Bulldog Winches
I like the 10,000 lbs integrated bulldog winch, but they are relatively new to the market...I think. Looks like a solid winch from the specs. I compared it to the 9500lbs integrated Mile Marker winch, both are in the $650 to $675 range. Any input or suggestions on either winch. Warn and Ramsey and the others are too many pesos. What would be the main advantage or disadvantage of having an integrated winch as opposed to a non-integrated? Can the non-integrated winch have the solenoid box mounted up higher in the engine compartment?
http://www.rockymountainsusp.com/winches.htm
http://www.truckaddons.com/Catalog/s...ch_7650147.htm
The Goat
Old 05-03-2007, 04:48 PM
yat74's Avatar
Default Re: Bulldog Winches
Found the Mile Marker integrated 9500lbs winch for $585 on central 4 wheel drive .com.
The Goat
