Old 05-04-2007, 05:13 PM
johndjmix1's Avatar
johndjmix1 johndjmix1 is offline
johndjmix1 is off the scale
Default Part throttle shift points...
I have been trying to locate a computer programer that will allow me to program part throttle shift points. The hypertech says it can do this, but after going through the manual on line i see it only changes this when you change the tire size setting.....i have stock tires and this doesnt give you much control anyways.
The shift that always bugs me is the slow speed downshift from 2 to 1. Example. You pull out of the driveway and slowly accellerate up to 20 or so then hit the brakes and slow for a turn, after the turn the H2 is in 2nd gear and you have to press the pedal almost all the way to the floor in order to get a downshift to first which is then very Violent. This is VERY VERY VERY annoying.
I want it to pop down to first easier, with less pedal pressure. Is there any programer that will do this? Does the hypertech just automaticly fix this lame problem???
--John
2006 Hummer H2 Lux Series
www.JohnHasMoreFun.com
1/4 Mile 15.29@91.34mph
Mods:
Warn 9.5 Winch
