Old 05-06-2007, 02:12 PM
Roadman's Avatar
Roadman Roadman is offline
Roadman is off the scale
Default Problem Starting
Has anyone ever had problems starting after a short trip to the store? It would just crank. It finally started after a few attempts and made it home. When home tried it again and no problems. Could it be fuel related? The battery seemed fine.
Old 05-06-2007, 02:39 PM
fourfourto's Avatar
Default Re: Problem Starting
No problems fires right up ,I did have a bad battery march 06 but then it didnt crank.
I see your near Albany ,Any interesting trails around.
My mother in law has a house in bainbridge 1 1/2 hours from you I find snowmobile trails /logging roads all over that area. We go up there every couple of months.
Name:  Upstate house.JPG
Name:  hum window.JPG
Name:  snowmobile trail sign.JPG
Old 05-06-2007, 03:12 PM
yes
Old 05-06-2007, 07:03 PM
Sounds like a fuel pump relay. Take it to the dealer.
Old 05-06-2007, 08:12 PM
Could be fuel related, could be ignition related. There have beens ome known ignition switch problems causing this type of hard-start.
Old 05-06-2007, 10:38 PM
Roadman's Avatar
Thanks for the replies everyone. Yes I guess I will have to take it to the dreaded dealer. Four Four Two, I have yet to find any good spots around here or points north but I'm looking.
Old 05-06-2007, 11:26 PM
fourfourto's Avatar
Look for snomobile signs on opposite sides of the road about 1/4 mile apart.There all over upstate. The trail will be somewhere in between.
Good luck at the dealer,Is ther one close to you.
Old 05-07-2007, 12:15 AM
Roadman's Avatar
About ten miles
Old 05-20-2007, 03:04 PM
Roadman's Avatar
Thumbs down Re: Problem Starting
Dealer Repair, check for code B2960, clear any codes give back to customer.
Old 05-20-2007, 03:09 PM
glitch, took me three times to get them that they didi the only oil change the truck ever had and did not tourque the plate bolts (one fell out) then they said they would order one ( week or so) I said naaaaa go find one. they took one off a stock truck and made it seem like they were moving heavan and earth.
Old 05-20-2007, 03:25 PM
B2950-Passlock, one of the repairs is replace ignition lock switch module, or loose connections.
Old 05-20-2007, 03:39 PM
Roadman's Avatar
Thanks for the info.
Old 05-20-2007, 07:01 PM
Dani Dani is offline
Dani is off the scale
Mine never had problems starting. It'd start but run really rough for a good 5-10 minutes before it would run normal.
If the broom fits, fly it!
Old 05-20-2007, 07:24 PM
nope
Old 05-21-2007, 07:50 PM
no complaints here..
Old 05-22-2007, 04:14 AM
fw888's Avatar
fw888 fw888 is offline
mine start right up, no problem...
06 H3 Boulder gray,
Adv. Pack, Chrome Pack, Chrome Step Assist, Chrome fuel cover, Chrome Hood with handle, Chrome air intake, Chrome side marker light, Oem Brushguard, Tow Package, Factory Mudflaps Front/Back, XM Radio, OnStar ... more to come
