05-15-2007, 05:07 AM
front locker
was told someone came out with a front locker for h3?? can not find!
anyone know to get gears for front diff. only thing i can find is 4:56
same as factory.
thanks for any info glenn
05-15-2007, 06:09 AM
Re: front locker
i wouldant put one in the aluminum housing  but be patient , all hope is not lost
05-15-2007, 07:31 AM
Re: front locker
Do you just want to be able to grenade it faster?
05-15-2007, 03:45 PM
Re: front locker
is it spin and grab or wheel hop what is braking diffs??? would the locker stop some of this with throttle control???
05-15-2007, 04:23 PM
Re: front locker
Cast iron would only be part of the solution.
No tukr, it is "housing flex" that causes the teeth to be stripped from the ring gear.
However, it is a 7.25 inch ring gear. Waaaay to small for a 5K lb + 4x4.
I would not put a locker in a 7.25 inch front diff. Needs to be at least 8.0 and even then you have to be really careful.
I'm not sure a front locker is even needed. I've never, to this point been in a situation where someone said, "Hey Beebs, if you had a front locker, you could have stomped that obstacle".
05-15-2007, 05:54 PM
Re: front locker
Eight inches or more would be ok (differential you perverts), and yes, as NEO stated, be patient....
I agree with Bebe, how often is a front locker really needed? However, if you do need it, it would be nice to have.
05-15-2007, 06:06 PM
Re: front locker
A front locker would be useful in some situations. We are waiting patiently
I would rather have control over the front diff rather than having traction control/abs kick in.
I have had ARB's front and rear in a YJ and my Rubicon has lockers front and rear. No complaints.
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
05-16-2007, 03:06 AM
Re: front locker
sorry bro i told you wrong i thouhgt it was out, Sedona lifted h3 right?
05-16-2007, 03:47 AM
Re: front locker
no problem Sam. yes lifted h3. had great week end!!
05-16-2007, 04:53 AM
Re: front locker
Is there something implied that you can't tell about yet??
05-16-2007, 04:57 AM
Re: front locker
05-16-2007, 06:46 PM
Re: front locker
Love those bananas
