Old 05-17-2007, 07:24 PM
TOPLINE's Avatar
TOPLINE TOPLINE is offline
TOPLINE is on a distinguished road
Default oil grade
just been offered a amount of fully synthic oil 5w-40 from FORD MOTOR CO is this grade ok to use in my hummer h2 over here in england as we dont have anywere like the cold weather you have over there
cheers shaun
CHEERS
Old 05-18-2007, 01:35 AM
IRA51's Avatar
IRA51 IRA51 is offline
Default Re: oil grade
that should be ok,kinda parshal to Mobil 1 10/30 my self .
A government big enough to
you have.
-- Thomas Jefferson
Old 05-18-2007, 12:42 PM
nmu98 nmu98 is offline
nmu98 is on a distinguished road
I am not an oil guru, but i say hell no. If you use 5w30 or 10w30, My guess is that only in really cold starting could you wear anything more than normal....
You are upping the weight of the oil when its hot by going to the 40. These new engines are built with very tight tollerances and designed for a specific oil. most Fords now want 5w20 and caution the use of 5w30.
Old 05-18-2007, 04:31 PM
IRA51's Avatar
i HAVE USED 10/40 IN MY 2000 Z28 with a 382 stroker motor motor (LS1) 450 hp at the rear wheels (11.86) in the 1/4 mile and street driver in Phoenix for 6 years with no problem 26000 miles and runs like a champ .
you have.
-- Thomas Jefferson
Old 05-18-2007, 04:58 PM
OK, but that is not a 6.0 in a Hummer, and has WAY more HP... You would want the higher wieght oil for less shear in that engine....
I am not saying I know right or wrong here... I am just sharing my idea.....
Old 05-18-2007, 08:32 PM
mdoyle mdoyle is offline
mdoyle is on a distinguished road
You guys can't compare various motors and grades of oil and draw any conclusions about performance. The viscosity oil is specified for a particular motor design and it's not necessarily about quality this or quality that.
The main key is this- bearing clearances and their L10 life are based upon the formation of a hydrodynamic wedge of oil between the running surfaces. The viscosity is specified for that clearance and a few other variables, but mainly that one clearance.
What happens with a sleeve bearing like the ones on the crankshaft, connecting rods, and camshaft is this: when a shaft turns inside a cylindrical bearing that is oil lubricated, instead of the oil flowing outward like you'd expect it pushes inward from both sides forming a pressure ridge in the middle. This wedge formation supports the shaft that's turning inside it.
Since the wedge isn't present at start-up, that is when most of your wear occurs. It's also the reason turbo equipped cars usually have a pressure reservoir to supply the turbo bearings after shut-down while the impeller is still spooling down.
Stick to the manufacturer's oil specs, avoid "snake oils" that make absurd claims, and use the right SAE ratings for your car and you'll do well.
Old 05-18-2007, 10:38 PM
IRA51's Avatar
after 50000 or 60000 miles of wear the clearences are no longer the same ,they are larger and a slightly heavyer weight oil will in fact preform the task of keeping a nice oil wedge between the bearing and the crank very well. also with wear the oil pump will no longer deliver the same presure as it did when new . all I'm saying is a slightly heavyer weight oil will work well .I have had over 20 6.0 engins apart for rebuilds (they go about 160000 miles on trucks that have been maintained) and a lot less if you tow heavy up hills in the Arizona heat . we have put 15/40 Dello in a 5.3 in an Avalanche with81000 on it and it now has 120000 and it is still running great and he pulls a 24 ft Cobalt boat to lake powell 30 times a year and the boat and trailer is 8700 lbs ,it does not use oil between changes.now if the temp drops below 32 degres it's a diff story . what I have found is the best in an ls1 type engine in Arizona heat is red line oil ,Mobil 1 in 10/30 is almost as good and cheaper and you can get it at Wmart or Costco for under $30.00.
you have.
-- Thomas Jefferson
