Old 05-19-2007, 03:10 AM
Mr_Pat's Avatar
Mr_Pat Mr_Pat is offline
Mr_Pat is an unknown quantity at this point
Default Rocky-Road Rocker Protectors (I bought a set)
So I was on the fence trying to decide between Rocky-Road or OEM rocker protectors. I went with the rocky-road and I couldn?t be happier. These things are heavy?. heave duty, with out a doubt. (they also come with a life time guarantee not to bend, dent, break) Holes lined up perfect, it was a tight fit on the side with the e-brake but it fit. One issue I had was two of the threaded holes in the frame that have never been use had to be tapped. I started the bolts and it started to get really tight I backed em out and the threads were jacked up. I had to pull out the tap and die set and clean the holes and rethread the bolts. I also used some blue lock-tight on all the bolts. On a scale of 1-10 they are a 10
