Old 05-20-2007, 04:45 PM
cmd's Avatar
cmd cmd is offline
cmd is on a distinguished road
Default H2 suspension question
Hello, I have a 03 H2 and the truck sits higher in the rear, looks like it is jacked. It had air and now has coils with the stock shocks which i understand have a longer travel, will this result in the truck riding slightly higher, any one experience this. I checked the front ride z height @ 4.5", it is ok, if 4.5" is the correct#?
Old 05-21-2007, 03:42 AM
tomp's Avatar
tomp tomp is offline
Default Re: H2 suspension question
Stock shocks with coil springs will result in higher ride height over some low pressure aftermarket shocks, as the stock shocks are high pressure charged. I am not sure how they compare to the air suspension etc
Old 05-21-2007, 07:41 PM
IRA51's Avatar
IRA51 IRA51 is offline
What made you change from bags to the coil springs ?
A government big enough to
you have.
-- Thomas Jefferson
Old 05-23-2007, 07:24 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Shocks have no bearing on ride height, just ride quality. Shocks just control the ride, springs set the height. All h-2 with coils ride higher in the back to compensate for cargo weight, where air springs can automatically compensate for cargo load changes.
