Old 01-23-2006, 09:41 AM
Ernie Italy is off the scale
... goes out.
To be replace with pitman and idler...
... goes out.
Old 01-23-2006, 01:03 PM
an hit to left...another to right... some hole at high speed... a lot of bump... standard off-road use....
It start when I read a article on offroad.com about Cognito pitman kit. Lift the driver side wheel and surprise it move and the other no!
It's a all-around problem of play on pitman idler and steering box....
Old 01-23-2006, 01:38 PM
can depend about a little crank of torsion bar ?
Old 01-23-2006, 03:00 PM
mmmm but take in consideration that my z height are on the lower limit of GM specs (I can lift a little too...) I think that the problem is due to the first tree roots that I have hit very hard ... the tie rod RD are safe but the impact have damaged something...(the pitman) now the truck is on the air and we are evaluate what is the problem....
