Old 05-23-2007, 07:53 PM
Talking Does anyone have this brake caliper upgrade?
I have the stock wheels and a big brake upgrade is not possible without a bigger wheel which i dont want, so has anyone used SSBC 3 piston brake calipers? they claim up to 16% more braking torque. i have price them at $750 for the front pair. Do you think 3 pistons over the factory 2 piston calipers design will make a difference?
Caliper Specs:
Force 10 Tri-Power HD 3-Piston aluminum calipers
Number of Pistons 3
Piston Size 51mm
Constructed From Lightweight Aluminum reduces "unsprung weight"
Standard Finish Clear Anodized
Optional Finishes Polished or Powder Coated
All hardware included
Bolts to stock spindles
Calipers come with clear anodized finish
Includes high performance pads
Reuses stock cradle brackets
Fits stock wheels
NOTE: Must be used with stock size rotors
Heres the factory spec web page
http://www.ssbrakes.com/products/det...l=H2&year=2006
Let me know if you have them, how did they work for you, how much did you pay.
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
