05-24-2007, 08:04 PM
sunroof....
is acting up.....
i'll go to close it......it stops halfway and go's back
in order to close it i have to "help" it along
05-24-2007, 08:16 PM
Re: sunroof....
I love it when stuff like that happens. Use to have a Grand Cherokee that the same thing would happen to the windows.
--John
2006 Hummer H2 Lux Series
www.JohnHasMoreFun.com
1/4 Mile 15.29@91.34mph
Mods:
Warn 9.5 Winch
05-24-2007, 08:54 PM
Re: sunroof....
I'm on my second sunroof assembly and it still does that.
05-24-2007, 09:27 PM
Re: sunroof....
Mine does the same, but I notice it only does it if I turn the car off half way during the close procedure.
If I wait for it to close before turning car off, no problems.
Also, it did happen once while rolling up the windows and sunroof at the same time. Probably some goofy polarity issue
Carless... riding the bus...  Trying to decide on which 08 H2 to get
05-24-2007, 09:34 PM
Re: sunroof....
it does it every once in a while....i figured it just needs a lil lube....
*hopefully*
ive only had it a week....its an 05 for ****s sake!
05-24-2007, 09:36 PM
Re: sunroof....
Im not sure if this work for Hummers but on my BMW if you hold down the sunroof button for 30 seconds (in close position) it resets it self. Worth a try I guess...... Can you get in the opening to add some grease?
09 Challenger R/T
95 Heep Wrangler
90 5.Slow
99 HMC4 Sold
01 HMCO Sold
04 H2 Adv Sold
03 H2 Lux Totaled
HOPE Volunteer
05-24-2007, 11:13 PM
Re: sunroof....
Had mine in 3 weeks ago for the exact same thing. To fix it they took the headliner, cleaned and lubed the tracks.
2008 H3 Alpha - Boulder Gray
05-25-2007, 05:06 AM
Re: sunroof....
Good chance the guides may have broke, only part available is A complete sunroof module as far as I know. Had to change many for the same symtoms. If your lucky maybe your dealer has A bad module(as in the whole sunroof assembly) that is bad and the guide you need might be ok. Hope that helps.
05-25-2007, 02:00 PM
Re: sunroof....
I had a Chrysler 300c and my roof did that all the time! It had some kind of sensor to stop the sun roof from "crushing your fingers". The windows also had these sensors.
I would hit the button to put up the windows, they'd go half way up, the come back down....
05-25-2007, 03:04 PM
Re: sunroof....
Ghosts in the machine.
05-27-2007, 03:28 PM
Re: sunroof....
if i just turn off the truck, close the sunroof and hit the global up on the windows, when the windows all hit closed at the same time, it appears that the voltage drop causes the safety feature of the sun roof to stop and then reverse direction. Just my theory on this event. Could be ghosts too....of hummers past...
2009 H2 Silver Ice LE
05-27-2007, 05:17 PM
Re: sunroof....
try to do one thing at a time, see if that helps....if not, take it in...unless the mileage is high, 05 is still under warranty...
