Old 05-30-2007, 05:49 PM
MDimitri's Avatar
MDimitri MDimitri is offline
Default TRAIN HORN IS INSTALLED!
Yea baby!! Got my train horn finally installed last night! Great job on the install goes to Jeff at SHAW GMC, flippin expensive, but nice install. All the wiring, hoses and components are clean and protected. Mounted the compressor and 3 gallon tank in the muffler housing under the truck. The switch to activate the horn is under the dash on the right hand side, when you switch it in the "OFF" position the regular horn is oporable, but when you switch it to the "ON" position the train horn is turned on. Sweetest part of all is that all I need to do is lay on the steering wheel's horn to blast either of them.
Pic's are coming!! I'll Also add sound and Videos!!
