Old 06-07-2007, 10:50 PM
jmsspratlin's Avatar
Unhappy Bad Smell
I have noticed over the course of the last month that the air conditioner smells bad. I have tried everything from smelly things from Kirklands, to no rolling the windows down, recirculating the cabin air, and spraying cologne. I do know that the moisture builds up inside the air ducts and if you do no run the regular air through them after the cold air moisture has hit, then mildew can form. I have done this, but still I have the problem. Has anyone else had this problem, and if so how did you get rid of it? Thanks in advance.....Jamie
