06-11-2003, 12:01 PM
I just got through putting an AirForce One system on and was not happy with the product at all. But it did bring up an interesting dilemma.......you change out the oem air box you run a big risk of sucking water when stream crossing it would seem...
Am I thinking right??
Anyone successfully changed out the stock air box and still played in the water???
Anyone with a snorkel??
Many thanks for the help!!
Age is a state of mind, if you don't mind, it doesn't matter.
If you\'re following me, you won\'t make it!
06-11-2003, 12:17 PM
It is one of those situations where you can have one or the other. I also have the AirForce One and really like it. However if I am going to any serious off roading I just switch it out. The factory air box was designed with water in mind someone will make a better flowing filter for the factory airbox soon. The only one right now is the Airaid filter.
http://www.macromotive.com/shopping/goShopping.cfm?sid=86A577939984437D9652DFF3B81168F E&tag=4.2.3.0.4500.34374
06-11-2003, 12:32 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> Anyone with a snorkel??
<HR></BLOCKQUOTE>
You might want to do a search for some threads on the factory's position on exceeding the design limits of the H2. If the water ever gets deep enough for a snorkle you are going to have far more problems(electronics, EVAP canister vent, etc) than what the snorkle will prevent.
Don
06-11-2003, 01:20 PM
Appreciate the help...........
As far as the AirForce one kit, the instructions were way off with respect to the H2 install.......just "generic" instructions that were for a 6.0 engine and some of my components were not the best quality.......
06-11-2003, 03:29 PM
I recently installed the airaid intake. I haven't noticed any difference whatsoever other than my wallet being 200 dollars lighter.
06-11-2003, 07:29 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by OUSUCKS:
I recently installed the airaid intake. I haven't noticed any difference whatsoever other than my wallet being 200 dollars lighter.<HR></BLOCKQUOTE>
I'm surpised. I really believe my airaid has helped performance. Especially, 1st gear ,last half of rpms before shift point. Of course now I'm driving around like a madman, winding out after every stop!!
06-12-2003, 01:30 AM
.[/quote]
I'm surpised.[/quote]
opps. that kinda looks like "I'm sure pissed"
it should have been "I'm surprised"
06-12-2003, 03:28 AM
I ordered the Airaid and had it in hand.
Then I was told NOT to install it by LPE. Two things happen:
1. When wheeling you can suck in water, and
2. The engine will suck in hot air which effects performance in a negative way.
I think I will believe them on this issue.
Black Lingenfelter Lux
06-12-2003, 01:24 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by blg615:
.<HR></BLOCKQUOTE>
it should have been "I'm surprised"[/quote]
I agree with #1 but not as much on #2 since the product comes with a heat shield. Not the best one in the world but it does include a shield.
2002 Vette; Vortex Intake, Vortech S/C, Stage II heads, comp cam (220/220/114/.581), 3.90 gears, 14 inch cross drilled rotors, 170 stat, NGK TR6, B&M Ripper Shifter, Autometer Boost & Fuel pressure gauges on a-pillar, Hotchkis Sway Bars, HRE 543 wheels (F:265/35 R:295/35), Z06 titanium exhaust, RK LT headers, Magnaflow x-pipe, Programming by Morgan Motorsports, 5% tint, AA Frame & Rocker Savers, TB Bypass, Lowered 2", Custom Audio;570 RWHP Dyno Here
2003 H2; 37 inch tires, Manik Off-Road pkg., Airaid Intake, Custom Audio
2003 H2; 37 inch BFG\'s, Manik Off-Road pkg., Airaid Intake w/MTI tube, Magnecor wires, Predator Tune, Custom Audio
06-29-2003, 12:40 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by KenP:
<HR></BLOCKQUOTE>
Last night, after some hard street driving, I open the hood and felt the airaid filter and the air tube around the MAS. Both were pretty hot feeling. This makes me wonder if there is too much hot air being sucked in.
I always thought these intake systems were advertised as "cold air intakes".
06-29-2003, 12:52 PM
Xtreme flow uses the stock box...just changes the filter.
06-29-2003, 01:42 PM
I believe the K&N kit does the same.....
07-01-2003, 01:46 AM
zyx does K&N make one for the H2, last time I check they didn't May 03
07-01-2003, 04:14 AM
K&N doesn't, Albie is right. I called them about a week ago. They're "working on it". No ETA.
All I can say to all the open box filter guys here is: if you plan to really use your H2 as designed (i.e., off-roading) and you encounter water crossings or such, it is nearly guaranteed you are going to suck water with these open air box filter systems.
I have had my H2 in almost mirror depth mud and frame depth in water and both times my engine compartment was completely full of both as I drove through it. In fact, my mud trip literally encased my engine compartment with mud, clogged every one of my radiators and packed the underside of the "Vortec" electronic cover. The H2 has very little protection from direct water flow inside the engine compartment. All the factory pieces are designed to prevent water intakes.
GM has made it painfully clear, no coverage. If yours is just a street rig (or beauty queen as my buddy calls them), go for it.
07-01-2003, 04:19 AM
Thanks Drop, you should join us on our So Cal runs.
07-01-2003, 04:40 AM
This may all be rumor but I overheard some guys talking the other day about a wrap that goes around the filter, whether it be K&N, the Air Force One, or the Airaid that will keep water out and only let air in.. Not sure of the specs of this, but I know that the guys at NASA have something that is similar. I like right near NASA so I hear these guys in restaurants talking about all kinds of stuff and what they are working on, and it appears as if they have a super polymer material that will do this.. If there is anything out there that I do not know about or have just been blind not to see it then forgive me... Just telling you what I heard....
BADRAP
03 H2, Lux, Pewter
H2 Club - Houston Chapter..
badrap@sbcglobal.net
07-04-2003, 12:09 AM
The last thing NASA needs to be worrying about right now is finding a way to allow an H2 to drive through a river.
