06-10-2007, 03:41 PM
2005 h2 cruise won't work
Fuse is good and cruise wont work any Ideas?
06-10-2007, 04:35 PM
Re: 2005 h2 cruise won't work
Take it to the dealer
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
06-10-2007, 09:53 PM
Check your brake lights. If the high mount brake light is in-op it will disable the cruise.
06-11-2007, 09:48 PM
High mount 3rd brake light works , taking it to a dealer ain't no big deal it's just 2 hours each way and if it is something simple I can take care of it as they say time is money and 4 hours travel time is wasted $$$$$$$$
06-14-2007, 03:10 PM
Please someone help me, I did not realize I used the cruise so much until it broke.Even though I bought the extended service -waranty policy It just turned 38000 miles and I supercharged it and we all know how much of a jack arse some dealers can be about that. Even if I wind up having to pay for the repair if it is something simple I wan't to take care of it myself.
06-14-2007, 07:03 PM
You can check your ign 3 fuse
06-14-2007, 07:08 PM
I know you checked the center high mount brake light, but get someone to hold the brake pedal and tap on the light itself I have seen some that are intermittant and tough to find, found the first one I saw by fluke. I was kicking it out as A no fault and someone noticed it did not come on, worked fine when I checked it and after banging on it it started to work again, swapped it out and no further concerns.
06-15-2007, 05:24 PM
Thanks for your help I will try that this afternoon after work and will post the result.
07-01-2007, 04:48 PM
I have done everything I could think of all the codes pointed towards the brake pedal switch replaced that still no cruise. Anyone out there ever have this problem?
07-03-2007, 09:26 PM
