Old 06-11-2007, 06:34 AM
springrnco springrnco is offline
springrnco is off the scale
Default Tire size w/ 2" body lift
I am currently installing a RubberDuck 2" body lift on my 2003 H1. I also have 40" Pro Comp X Terrains ordered for it but I am concerned that the 2" body lift will not be sufficient to fit the 40's. Any help would be appreciated. Thanks.
Old 06-11-2007, 04:38 PM
Default Re: Tire size w/ 2" body lift
39" Iroks.
Old 06-12-2007, 12:23 AM
ssgharkness020147's Avatar
The 40's will clear but it will be a bit tight. Make sure you grind down or reverse the bolts that hold the rocker pannel protection on the front of your truck, you'll see the bolts sticking out in the wheel well.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
Old 06-26-2007, 12:54 AM
BACKNBLACK's Avatar
BACKNBLACK BACKNBLACK is offline
BACKNBLACK is off the scale
38" are the largest tire you can go on stock H1 Height. Unless you do a BODY lift that does not change. The clearance will be the same. Once again thats GM/Hummer talking. IF it was me I would go with the 40" IROKS :-) on KMC Rockstar wheels
CURRENT HUMMER:
Number# 11 2007 H3x Desert Orange
SOLD BUT NOT FORGOTTON
1995 H1 350 HT GAS Black
2001 H1 Open Top Black
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
2008 H2 Black/Sedona
2009 H3T Alpha Solar Flare
Old 07-02-2007, 10:16 PM
smitham smitham is offline
smitham is off the scale
I have a friend who put a set 39.5 Irocks on a stock 99 before he had a chance to install the lift and he did not have any problems. We actually went off road and through various terrains without any rubbing issues. It might not be the best thing to do, but it did work, and if you install a 2? lift I am sure that there would be no trouble with 40? tires.
1997.5 4 door Hardtop for me
2006 H3 Advenure Pkg for her
