06-15-2007, 06:29 PM
lifted h2 with roll.....
i just got my h2 lifted with a 6 inch fabtech lift.. i love it... the only problem is their is alote of roll i guess you call it .. when you turn the wheel . its worst at high speeds.. like on the high way, it is alittle much.kinda scarry sometimes... i got the fabtech steering stablizer installed with the lift... so i was just wondering what i could do that would help with the roll...? would the dual shock kit help alote? or is their something else that might work better. ? also what gears would i want to change to help get some power back? thanks alote
06-15-2007, 10:26 PM
Re: lifted h2 with roll.....
Are the sway bars hooked up ? if not than you are going to get a sloppy ride . If you installed biger tires with tall sidewalls that will also give you lots of flex in the corners and at highway speeds .
A government big enough to
you have.
-- Thomas Jefferson
06-16-2007, 01:23 AM
YOu may want to look into tougher sway bars. That may help some. What shocks did you go with and what tire/ rim setup. That will help others with some suggestions. There are quite a few with that lift on this site.
06-16-2007, 02:07 AM
thanks for the help.. i went with 37 x 13.50 x 20 nitto mudd grapplers. yes the sway bars are attached.. but maybe i need heavy duty ones.. what do you suggest.? i just went with the fabtech shocks that came with the kit. so maybe the dual shock setup would help with that. ive also seen a dual steering stablizer, but im not sure if that would help...heres a pic thanks !
06-16-2007, 12:35 PM
nice looking rig. I concur with the prior comments. Also you must figure that if you are raising your center of gravity, you will tend to get more body roll.
2009 H2 Silver Ice LE
06-16-2007, 07:31 PM
NICE RIG! THe steering stabilzer is worth the money..esp. if you are going to off road the truck. It will not help with your issue, but it will make input to the steering much better.
Edelbrock trailering arms and sway bars and panhard rod would be your next trial of mods. Phil D had these on his H2. He also had the fabtech kit. You may want to send him a PM to see how he liked them.
06-16-2007, 07:54 PM
thanks for the info... i do have the fabtech single steering stablizer.. but i thought i saw a dual one.. i didnt know if that would make a difference.. but i take your addvice on the trailing arms and sway bars maybe that would tighten everything up alittle .. its not bad now, i just was hoping to improve it alittle bit more..just sways alittle to much. i also have the hypertech programer i wasnt sure what setting to use beside the one for the bigger tires .. anyone have any suggestions . thanks alote !
06-16-2007, 08:50 PM
Before you do anything, wait. You need to let the truck settle into it's new configuration for a while. Mine was the same way when I got it. Frankly, it was a bit scary to drive for the first fifty to hundred miles.
After that, things settled in nicely and the truck drove great.
06-16-2007, 10:11 PM
Yeah, it was scary. going all over the place. It definitely got better.
06-17-2007, 12:06 AM
Here's what mine is set it:
85 octane
dial in your tire size: check to make sure your tires are a true 37" tire from the manufact's site before setting.
shift fimness: harder
increase rev limiter to second from the highest setting
1-2 gear +4
2-3 gear +5
3-4 gear +6
This seems to work best for my style of driving.
06-17-2007, 02:13 AM
sounds good. thanks for all the help.. ill give it a try with those hypertech settings .. also that is good to know about the "break in period" that makes sense.. ill give it some time..i love the look of the truck and being up higher and it did great in the mudd.... the place that did the work wants me to bring it back in 1000 miles to check out everything and make sure everything is good..... would it be a good idea to get different gears? to try and get alittle power back if so which ones. 4.88? .. thanks
06-18-2007, 01:30 AM
I did 4:88 gears in mine and it was about perfect with 38" tires. With the 37's, its gonna be geared a little high. That will give you more power but you'll be spinning higher RPM's down the highway which will make your gas mileage suffer more.
As far as the body roll, the only thing that will help it is a stiffer sway bar. You can buy them for the H2, I considered it with mine but it must have "settled in" as Ken says cause it stopped bothering me, I assume it got better without me actually realizing it.
MINE - 2006 H2 SUT
06-19-2007, 06:52 PM
i think you guys are right.! it does seem to be settleing in alittle more.. feels better or im getting used to it.. anyway i like it . thanks for the help. i still might look into a better sway bar. ill wait and see how it drives after alittle more time.
06-21-2007, 09:07 AM
Ken is correct. Let rig settle some first and it applies to any rig lifted. The next thing I would do and most likely anyway would be to go with larger diameter sway bars and see how it handles. That is there main function anyway.
Good Luck!! You are getting some sound advice on the forum.
Wish i could be on and offer more help. Health issues keep me from doing allot of things these days that i would like. Hope to get back on more and bug everyone again.
TAZ
