Old 06-15-2007, 08:47 PM
Default Attn RYD - HOW TO QUOTE SOMEONE
This is primarily for our friend RYD, but may help others.
To use the "Quote" function, do it this way:
Click the "Quote" button like you've been doing.
You can then type your response BEFORE or AFTER the quotes. However, when editing, or correcting your post, you have to be careful NOT to erase the brackets. This is easy to do by accident. It's best if you put a space or two between your work and the quote brackets.
If you mess up, you get this:
Got it?
