Old 06-25-2007, 02:16 PM
genob genob is offline
genob is on a distinguished road
Default Installed My Amp/Sub (Write Up)
Hey All,
Here is my tech write up of how I installed an amp/sub combination in my 2007 h2. I used a box I built out of 3/4inch plywood which was ~14inches tall x 13inches wide x 13 inches deep. It housed a kicker cvr 10 with a 225 watt mono amp mounted to the side. The box was made to fit where the 3rd seat goes, and everything was connected using quick disconnects. It's bungeed down to the 3rd seat frame mounts.
We all know the Bose sub has no kind of output whatsoever! I ended up doing a bit of research on that magical internet and found a few different trains of thought on stereo upgrades... I didn't want to touch the factory stereo, plus I didn't want to remove the center console nor pieces of the dash.
I decided to splice a line level converter into the back speakers.
Now on to the steps I took to get this thing working:
1) Pop off the back pillar panels where the 2 speakers are located. There will be a small speaker plug all taped up. I tore some of the tape off about 2 inches from the plastic plug at the end of the speaker wire. Cut the wires and strip. Solder in new wires and run them under the panels (to where ever your new amp is located). At this point I wired everything up to my line level converter, and put it aside.
2) Now you have your speakers tapped, it's time to run the power (12 volts). I drilled a small hole under the driver side (it came out about 4 inches right of the steering assembly [if your standing in the front of the truck looking at the windshield]). I ran my 8 guage wire [yes only 8, i'm not using a ton of wattage in my amp] to the battery, remember FUSE FUSE FUSE FUSE!! Fuse until your heart is content!
After connecting the power wire, I then ran the rest of it under the panels by the driver side door (very easy to pull up panels and replace). I zip tied the power wire in different places for neatness sake.
3) Power is ready [make sure it isn't connected to the battery until your ready to turn everything on!!]. Now it's time for the remote wire. I ended up using the SEO ACCY fuse that is located on the driver side fuse box. I went to Pep Boys and bought a "mini add a circuit" which allows you to cleanly add a 2nd fused accessory wire. It's a beautiful piece of hardware! That way you don't have to shove wires down into the fuse blades...
Once I crimped the wire for the amp remote on, I then ran it down the same path as the power wire (down the driver side to the rear of the truck).
4) Now, I had to add ground. I just ran a piece of 8 guage wire right to the bolt holding the jack in place, very easy and right where I needed it to be. There are a zillion places to put ground, find one and wire it up.
5) I then put my box in and wired everything up to quick disconnects (bought all disconnects @ pep boys for under $20.00 total). I also used heat shrink tubing on the line level converter wires. I made it as clean as possible
A quick note: The rear speakers (bose factory) appear to get a full signal from the bose amp up front. I made a frequency test cd and tested all the way to 10 hz, and the kicker sub was responding just fine. I was hoping the factory amp wasn't rolling off the low frequency before it got to the speaker. When looking at the rear speakers I noticed they had caps installed to filter out the low end.
For me the kicker cvr 10 worked just fine, it gives your bose factory system the much needed punch. I tuned in the system to sound very clean with no rattles, or distortion... It has a low end like a home theater system.
Please feel free to correct any of my jabbering!
Just my 2 cents!!
Old 06-29-2007, 06:33 AM
(((echo)))'s Avatar
(((echo))) (((echo))) is offline
(((echo))) is on a distinguished road
Default Re: Installed My Amp/Sub (Write Up)
Not bad...thanx for the info on where to direct wire the remote...
But my "setup" will be a lil more complex...(note: all factory speakers will be replaced)
Amps used....
RockfordFosgate P4004, 400w 4channel...line level converted from each door speaker
RockfordFosgate P10002, 1000w 2channel (bridged)...line level converted from rear pillar
Front soundstage,,,
Rockford Fosgate T162S 6.5" Component Speakers
Rear soundstage,,,
Rockford Fosgate T162S 6.5" Component Speakers (must do a lil cutting to accomodate 6.5"speakers in rear doors)
Subwoofer's....
"2" JL Audio 10W7 10" Subwoofer's (each in seperate tubes to be mounted rear facing on rear fender wells)
with this setup i should be deaf in about a week or so
Old 06-29-2007, 12:40 PM
SnakeH2's Avatar
SnakeH2 SnakeH2 is offline
Great write up. This is exactly what I was wanting to do. Something simple that really gives a big improvement.
Originally Posted by genob
1) Pop off the back pillar panels where the 2 speakers are located. There will be a small speaker plug all taped up. I tore some of the tape off about 2 inches from the plastic plug at the end of the speaker wire. Cut the wires and strip. Solder in new wires and run them under the panels (to where ever your new amp is located). At this point I wired everything up to my line level converter, and put it aside. Did you wire both speakers into the converter, or just one?
3) Power is ready [make sure it isn't connected to the battery until your ready to turn everything on!!]. Now it's time for the remote wire. What is the remote wire? I ended up using the SEO ACCY fuse that is located on the driver side fuse box. I went to Pep Boys and bought a "mini add a circuit" which allows you to cleanly add a 2nd fused accessory wire. It's a beautiful piece of hardware! That way you don't have to shove wires down into the fuse blades...
Any pictures of your work?
Where's WiFey?
Old 06-29-2007, 05:02 PM
(((echo)))'s Avatar
SnakeH2.. the remote wire (usually blue in color from aftermarket radios) (labeled "remote" on all amps) simply turns on the power to the amp.
there are 2 circuits on amplifiers...1 direct from battery supplies the "umph" to push the amp...2 is the remote that shuts the amp on and off
Old 06-29-2007, 08:36 PM
SnakeH2's Avatar
Thanks. I did some of this stuff some years back, but it's been a few years.
Where's WiFey?
Old 07-03-2007, 01:57 PM
I didn't take any pics (my digital camera is dead [has been dead for about 2 years now]). I was going to use my cell phone cam, but it's kinda crappy.
My goal when doing all of this was NOT to really change out much, or hack much of the truck up.
I think the bose system sounds fine with the addition of some low end punch...
But, I also think upgrading all of the speakers would also help, but I didn't want to go through that headache... (no time).
I may end up replacing the front speakers with those recommended rockfords (in another post)... I'll probably go for the 2 way speakers since there are tweeters up on the pillars on top of the dash.
Old 07-03-2007, 02:11 PM
I wired both rear speakers to the line level converter. You want to do that because some studios will mix the low frequency signals into both channels but will run them out of phase. If you have only 1 speakers connected to the line level converter, it will cause your sub to sound like - "wobble wobble wobble..." because it's only getting half of the total low freq signal... it's safe just to connect both speakers into the 2 channel line level converter, then run the 2 outs into your amp, and let the amp mix them to a single signal out to your sub(s).
Amps have a wire which (usually) accepts a low current 0->12volt hold that controls the main power to the amp.
You usually wire it up to the ignition switch which will ultimately turn the amp on/off when you start/stop the car.
It's a way to not drain your battery by leaving your amp on when you get out of your car at night
The hummer has a VERY great fuse which goes high (12 volts) when you turn on your ignition. Again, I bought that fuse link (thingy) at pep boys [make sure you get the 'mini' fuse]. It's a piece of cake to run the remote wire right down and through the panels on the driver side to the back of the truck.
The really nice thing about the hummers are how the panels are clipped on!! Very easy to pop off, no crappy plastic clips [like most foreign cars]...
Old 07-04-2007, 02:13 AM
SnakeH2's Avatar
Much grass!!!
Thanks!
Where's WiFey?
Old 07-07-2007, 10:30 AM
vlxjim's Avatar
vlxjim vlxjim is offline
vlxjim is on a distinguished road
I'm going to add a sub as well. How did you "pop off the back pillar panels"?
06 H2 Limited SUV Pacific Blue
Old 07-08-2007, 06:35 PM
You simply have to pull the panels off by hand... I kind of worked them by tugging the edges a little, then they just pop off.
Old 08-10-2007, 11:45 AM
Tex_h2's Avatar
Tex_h2 Tex_h2 is offline
Thanks for the write up...
After spending 150.00 dollars (line converter, amp and sub) my bose stereo now has the little extra I was looking for.
Old 08-11-2007, 09:58 AM
Just for info sake Dragon can help with answers on sound equipment along with security and most any electronics stuff. He is honest if he does not know the answer he will find it out.
Not just playing home boy cards here Dragon is very good as i have seen his work on my completely sponsored sound system for Our show H2 but, I have watched him do a one amp one sub install and takes care to route and twist wiring so it looks just as professional as the $20,000 jobs he installs.
Bryan@HummerCustoms.com or Bryan@ motorsportsauthority.com
Tell him TAZ said on forum that he should be the one to answer audio/video/security/etc. questions. He stays covered up but, tries hard to answer all the questions he can. My system was a complete gut of factory sound system except OnStar box and replaced with a computer controlled unit with all Infinty components. If they were going to sponsor the rig they wanted all Bose equip. out (of course). So I think 4 amps 4-12" subs in rear custom built enclosures, and every speaker replaced right down to the little tweeters down on the "A" pillar on each side. It seemed like miles of wire ran on floor while interrior was stripped out to bare metal and head liner removed also. When i say the rig was gutted i really do mean all things removed then redesigned with a few installs and alot removed for changes. Dragon is extremely picky.
Well anyway he can help if you can get him to slow down long enough. Best to send an email through the forum as he watchs for members foremost as possible.
Good Luck,
TAZ
Old 08-18-2007, 02:42 AM
MVR 155's Avatar
MVR 155 MVR 155 is offline
I just added a sub/amp to the factory Bose using signal from the rear speakers to a line out converter..... its definately lacking on the very low frequency..... I too figured it would be a full range signal due to the capacitors on the bose speakers but you can totally hear it cut off on songs with very low bass... I even swapped in another amp and sub, changed polarity on the converter and the amp.... definately has some kind of cross over or capacitor somewhere else in the system.
I have the same set up in my TL and my Z06... I was able to run the signal from the factory sub in the TL but I had to buy a interface from PAC to get a signal in the vette (low frequency is not availible to the rear speakers). Can anyone here confirm if there is a good place to tap for low frequency signal or is it necessary to run a interface.
Mike
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 08-18-2007, 06:34 AM
vlxjim's Avatar
I use the rear speaker output and had great luck. I tested it with my audio test CD and had no dropout in the low end. I use a one 10" Polk/Momo sub with a MTX amp tested at 488 watts rms at 2 ohms and over 1200 peak. Its crossed over at 80hz and if you turn up the bass boost with the windows up it feel like the windows are going to break.
Old 08-18-2007, 11:45 AM
MVR 155's Avatar
I wish I had your luck with it..... Im definately getting a signal that does not get the really low stuff, I guess Im gonna order the PAC AOEMGM24..... I will get a unmolested signal for sure that way.
Like I said I tried different different amps/subs as well.... I have all good stuff, I tried my Rockford amp, my alpine amp and 2 different subs in the H2 yesterday with no luck. The stuff I tested with sounds absolutely perfect in my TL and my Z06
2013 Audi S4
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 08-20-2007, 04:31 PM
Maybe the older trucks highpass filtered the audio out of the stock amp?
Mine is a 2k7 and the signal passed to the rear was a full signal. I didn't want to have to get behind the factory stereo to connect anything (i didn't have the time to tear it all apart).
I made my own test cd which played a sine wave down to 10hz and the speaker moved (couldn't hear it though...).
I only installed a 200watt MTX (ended up running it at 2 ohms because i didn't care if i blew it up) in a decent size box i made with a kicker cvr 10.
Sounds nice, it isn't over powering...
Old 08-20-2007, 06:51 PM
MVR 155's Avatar
Well I ordered the PAC interface saturday morning as well as the Nucleaus ipod interface, I even tried swapping out the line out converter with the one in my TL (figured maybe something inside the converter could have been clipping the frequency signal.... long shot) with no luck. I would assume by looking at the bezel around the waterfall area of the H2 it looks to be quite simple to get access to the head unit to remove it. Should have the parts in a couple of days...... I will report back on the progress
2013 Audi S4
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 08-23-2007, 12:48 PM
MVR 155's Avatar
Wrote up a new thread on my results with the PAC interface..... Definately made the difference I was looking for
2013 Audi S4
1/4 mile: 10.51@136
2005 Sea-Doo RXT
