Old 08-26-2003, 12:42 PM
hummerbot hummerbot is offline
hummerbot is off the scale
I'm looking for a product that will fit in the front or rear 2" receiver on my H2 that has a bar that goes up as high as the roof rack so I can carry long pieces of wood molding. Anyone seen such a thing or am I going to have to build it myself?
Hummberbot
Hummberbot
Old 08-26-2003, 12:46 PM
Ben Ben is offline
Ben is off the scale
Try Overtons.com. Part 40863
http://www.overtons.com/cgi-bin/over...arge.cgi?40863
Old 08-26-2003, 04:20 PM
DURAMAX TIM is off the scale
I built my own so I could haul 16' stuff in the truck bed.
I used all 2"x1/4" wall tube and 3" channel for the top.
U might make a light duty one w/ 1" pipe and run a 6' piece of all thread thru it and put a top plate out of wood if your trim is fairly light.
Let the all thread go thru the top plate, pipe and your standard hitch tube then use nuts to tighten it up.
Could use 1 in front and 1 in back.
Cabelas has them too,http://www.cabelas.com/
98 ZR-2 Blazer
Ex H2&3 owner
Old 08-26-2003, 06:09 PM
BADRAP BADRAP is offline
BADRAP is off the scale
He said "pipe, tube and nuts" too....
Old 08-27-2003, 02:50 AM
H2 Daddy H2 Daddy is offline
H2 Daddy is off the scale
Sounds like he needs a big rack to rest his wood on.
Old 08-27-2003, 10:09 AM
Dan Dan is offline
Do some searches for Hang Glider racks. I used to be into the sport and have seen quite a few racks that would be perfect for what you need.
Im not sure if there are any commercially available ones, of if you'd have to build your own though.
Here are some ideas:
http://www.wonderwinds.com/Photos/glider_racks.htm
Good Luck!
- Dan
SUT on order since 12/02 - 10 months to go!
