Old 07-14-2007, 05:11 AM
ROUGHRIDER ROUGHRIDER is offline
ROUGHRIDER is on a distinguished road
Default BUZZING SOUND WHILE ACCELERATING???
2006 SUT all stock 17k miles. I have noticed a buzzing sound when under low speed acceleration. Any ideas? Thanks M
Old 07-14-2007, 02:23 PM
Default Re: BUZZING SOUND WHILE ACCELERATING???
No. Be more specific.
Where is the buzzing sound coming from? Does it change pitch with RPM's?
Help us help you:
Cockpit = OnStar mic
Engine = ?
Trans = check fluid first
Diffs = ?
Sunroof = ?
Old 07-14-2007, 06:38 PM
Mr. I - Man's Avatar
Help us help you:
Engine = ?
Diffs = ?
Sunroof = ?
Center Consol = Wifey's battery powered buddy
Glove Box = Your battery powered buddy
Fissed
Old 07-14-2007, 10:21 PM
It only happens while under acceleration at low speeds and only for a short period of time. Buzzing sounds like fuel pump to me. Not any type of alarm. More of a high pitch whine. It lasts for about 3 seconds then goes away. It happens almost everytime I take off. No change with RPMs. Sound is coming from around the engine. Thanks M
Old 07-14-2007, 11:30 PM
HUM GOOD's Avatar
HUM GOOD HUM GOOD is offline
HUM GOOD has a little shameless behaviour in the past
Maybe it's the factory supercharger whine -
Turn the wheel all the way to lock with the truck on - maybe low power steering fluid.
Old 07-16-2007, 01:17 PM
TXSUT's Avatar
TXSUT TXSUT is offline
Mine (2005 SUT) has done the same thing for over 40,000 miles. Dealership couldn't figure it out, so I've just ignored it.
Old 07-16-2007, 08:11 PM
CONRAD II's Avatar
Could be bees. This works for me...
66' VETTE STINGRAY
07' Z06
Old 07-17-2007, 05:04 AM
Dealerships R
Old 07-17-2007, 07:28 AM
Tallowood_Air's Avatar
Tallowood_Air Tallowood_Air is offline
Tallowood_Air is on a distinguished road
I've ignored so many sounds out of existence........... Working on a front end clunk right now.
2007 SUV LUX All-Terrain Blue
Polished Radix Magnacharger; 2.8" pulley; Tuned by HESCO; Custom 4L80E "Raptor" by PACT
GM 2500HD Efans on SPAL controler; K&N filter element; Dynatech Headers + Cats; Magnaflow cat-back
37" Kumho Road Venture MT KL71 on 24" ZINIK Mazotti
Pioneer AVIC-Z1 HDD navigation; 2 x 12" JL W6; Custom Box w/ Lights
Old 07-17-2007, 04:06 PM
TXSUT's Avatar
You too, huh? http://www.elcovaforums.com/forums/s...ad.php?t=28229
Old 07-18-2007, 05:40 PM
Powerfiend's Avatar
Powerfiend Powerfiend is offline
Powerfiend is on a distinguished road
Roughrider, I've got the same sound. I took it to the dealership and they couldn't figure it out. I was able to localize it to something related to the throttle body. I took the air filter out and put it back after blowing it off and the pitch of sound changed. I have about 12k miles on my 06' and it just started about a month ago. If the windows are down its more noticeable right around 2-2500 rpm.
06 H2 SUV....stock for now!
Old 07-21-2007, 11:59 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Ensure the air filter is fully seated into place, seen too many to count that were not properly installed and intake air passed by the filter. I use A small prybar to push the filter into the housing and it will then drop into place. You should see A small retainer at the bottom of the filter holding it into place if it is installed fully. Its A very tight fit so if it went into place easy it likely is not seated
Old 07-22-2007, 03:00 AM
Thanks, I'll check!
