Old 04-07-2006, 09:26 PM
The_Duck The_Duck is offline
The_Duck is off the scale
Hi,
I got the neo ion ipod adapter all installed.
It works and sounds great.
My only problem now is that I want to run the
cable lines through the center into my center
armrest so that I can hook up the ipod and leave
it in there.
How the heck do I do that? Do I have to drill??
I can't seem to figure out where to go from here.
Here is a picture of how far I got.
Thanks for your help.
- The_Duck
H3 Black 5-speed manual
Old 04-07-2006, 10:04 PM
You'll probably have to drill a hole to get it inside the storage area.
I haven't taken that section apart (yet ) but from the picture it looks like you should be able to run the cable along either side of the tray. Then you can drill a hole at the bottom of the armrest storage and fish it through there. Good luck.
Old 04-07-2006, 11:21 PM
If you drill a hole here doesn't it go into the storage area?
nmikes nmikes is offline
nmikes is off the scale
Holy crap... thats where mine is... got a hard case and drilled it into the recess there on the bottom of the armrest that flips up. only hole I drilled was at the base where the hinges are. From there I was able to feed it down and snag it with a coat hanger to tuck the length near the carpet to the dash. I didn't dis-assemble anything on the center armrest. Will try to post pics this weekend.
Old 04-08-2006, 01:45 AM
The cup holder top would be covering that area and I am not sure if there would be enough room for the wire once the cover is back in place. I was thinking maybe somehow getting UNDER that grey flat area you indicated.
Below are 3 more pics of the center area.
- The_Duck
Old 04-08-2006, 01:48 AM
more of the center area with the neo-ion/wires and where the top cupoholder snaps back down
- The_Duck
Old 04-08-2006, 01:50 AM
back of armrest where I think nmikes was referring to where he drilled a hole?
- The_Duck
Old 04-08-2006, 02:33 AM
Try to find something the same diameter or slightly larger diameter as the wire. Place it where you might drill, them place the cover back in place. If it doesn't hit the test item, then you should be fine.
Old 04-08-2006, 02:45 AM
Bully13's Avatar
Bully13 Bully13 is offline
Where did you get your adapter from? How much did it cost? Did you do the initial install yourself?
I don't have an Ipod, but I would love to have an open auxillery input for some other portable things I have.
Old 04-08-2006, 03:07 AM
yep, thats the place... however I wasn't entirely honest about not taking anything apart. If you unscrew the armrest, drill your hole you can run the wire around the hinge once you screw the armrest back down. So the hole drilled is unnoticable, being covered by the hinge.
Old 04-08-2006, 12:23 PM
Neo Ion
www.mp3yourcar.com $199
comes with all cables needed
I have the base 1cd-radio with no XM.
You hook this up easily and now the radio thinks XM is hooked up. XM1 is your ipod, XM2 is ... probably regular XM if I had it.
Then you have an additional auxillary RCA input which I think is a great feature. At any time you can add any item that you can connect with any RCA hookup.
The install was simple thanks to the many posts on this site (considering I don't have any car install experience). I have some install pics if you want to see them.
- The_Duck
Old 04-08-2006, 12:27 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by The_Duck:
Try to find something the same diameter or slightly larger diameter as the wire. Place it where you might drill, them place the cover back in place. If it doesn't hit the test item, then you should be fine. </div></BLOCKQUOTE>
Great idea. I'll try that
- The_Duck
Old 04-08-2006, 06:11 PM
This should give you some idea hopefully.
How it looks from the wheel.
Old 04-09-2006, 02:31 PM
Should I even bother to ask you how you fished that all the way underneath the armrest? Impressive.
- The_Duck
Old 04-09-2006, 04:23 PM
Sweet! I did it!
Thanks for the suggestions!
Here are the two final pics. The drillhole was a hackjob, but it worked.
- The_Duck
Old 04-13-2009, 03:05 AM
willcs37 willcs37 is offline
willcs37 is on a distinguished road
Default Re: run ipod line thru center to armrest
where do you buy one of these ipod adapters?....and how do you hook them up? help plz
Old 04-13-2009, 02:49 PM
terry_ohio's Avatar
terry_ohio terry_ohio is offline
terry_ohio is on a distinguished road
Don't go with that. Get one that's hardwired thru your factory stereo. Then you can use your factory stereo to control your ipod. Why have a bunch of gadgets all over the place. Save your money and get a new system that has everything.
Something like this.......http://www.installer.com/cars/by_car.php?carid=7688
STEELERS!!!!
Old 04-19-2009, 11:00 PM
bcart82 bcart82 is offline
bcart82 is on a distinguished road
Wow - wish I had seen that unit before buying my soundgate one...
Factory HU control would be where it's at, seeing as how the H3 offers no spots for unsightly, accessible ipod mounting.
