01-20-2006, 10:52 PM
I couldn't firgure out a good place or method for locating the HiLift, so I bolted it on.
I used two, 3"x 1/2" grade 8 bolts with shoulders, lock washers and Nylock nuts.
01-20-2006, 10:54 PM
Drilled a 1/2" hole all the way through the carrier and attached the bolts as seen in the pic above.
I then mounted the HiLift on the bolts and used one Nylock nut on one side. I didn't tighten it all the way.
When it's time to go wheeling I'll just pull the Nylock and replace it with another wingnut.
01-20-2006, 10:56 PM
On the otherside I used a wingnut.
The problem with mounting the jack back here is you will hit the tailgate when you lower it.
01-20-2006, 10:57 PM
So now if I open the tailgate, I remove the wingnut and swing the jack down out of the way.
01-20-2006, 10:58 PM
Piece of cake.
Finished product.
01-20-2006, 10:59 PM
One last thing, the bolt holes MUST be precise. You can't bend anything to fit. I found out the hard way.
01-20-2006, 11:58 PM
Nice work, <STRIKE>Macgyver</STRIKE> Ken. Very clever design!
\'05 SUT
01-21-2006, 12:27 AM
I wanted the 60", but I'd have nowhere to put that monster.
I was going to mount mine like yours, but the tire is in the way. That is going to change, I promise that.
I like the little padlocks. Instead I ran a 3ft cable lock around the back of the tire carrier and through a couple of jack holes.
For drilling through the metal I used a Black and Decker brad point 1/2" bit on a cordless drill. I couldn't believe the cordless worked better than the air drill. Must be a torque thing because the cordless went through it like butta'.
01-21-2006, 12:28 AM
Oh, isn't our jack nice and shiney.
01-21-2006, 12:47 AM
Do you guys also carry a base for the jack of some sort? If so where?
01-21-2006, 12:50 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by CslRkH2:
Do you guys also carry a base for the jack of some sort? If so where? </div></BLOCKQUOTE>
Yes, in a Trail Duty gear bag in the bed of the truck.
\'05 SUT
01-21-2006, 12:58 AM
How big is the base you use?
I really like the install Ken...but with the GOBI ladder I don't think it would work for me. I'm going to have to find something soon...[cough] hi-lift mount for the stealth rack[cough cough]
Hey has anyone heard from timgco in awhile??
You should get one of these... Handle Keeper
01-21-2006, 01:22 AM
Looks damn nice Ken!
01-21-2006, 01:40 AM
How big is the base you use? </div></BLOCKQUOTE>
It's the one pictured here: http://www.hi-lift.com/products/offroadbase.htm Can't say that I ever measured it but I'd guess it to be 10 inches square.
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">I'm going to have to find something soon...[cough] hi-lift mount for the stealth rack[cough cough]
</div></BLOCKQUOTE>
\'05 SUT
01-21-2006, 01:50 AM
Here is a link from Az Hog on mounting a Hi-Lift Jack on a SMA Tire Carrier, it will work for H1 & H2.
the web site is www.azhog.com
Look under Hummer Technical Information, and then look for Hi-Lift Jack Mounting for SMA Tire Carrier for H1 & H2.
I did the mount on my H2 and the cost for parts was right at $20.00
01-21-2006, 01:55 AM
You should get one of these... Handle Keeper </div></BLOCKQUOTE>Velcro for the handle. They even include it in this kit.
Mount it to your ladder.
01-21-2006, 02:01 AM
Here is another picture of the Jack Mounting.
