Old 07-26-2007, 04:30 AM
2345 2345 is offline
2345 is on a distinguished road
Default rancho?
Hi guys i am deciding to buy a rancho 4 inch kit and 37's on it and have a few questions.... "and i have search previous post"
1.how is the ride on the highway, and city driving
2.taking corners does it feel like you are going to roll
3.hows off roading
4.gas milage
5.is it worth it
THANKS
Old 07-26-2007, 10:54 AM
RuggedH2's Avatar
RuggedH2 RuggedH2 is offline
Default Re: rancho?
Are you planning to wheel that truck, or are you just lifting it for appearance?
If you are planning to wheel it with the lift, you might want to read and search a bit more before you spend the money. Search "Rancho lift" in H3 discussion.
It's been pretty well documented that the lift is gonna expose several parts (mostly in the front, ie. half-shafts) to problems off road.
Too bad too, because if FabTech built a real off road lift for the H3, I'd buy one. If the lifts worked as good as they look, I would have had one over two years ago.
Old 07-26-2007, 03:56 PM
Default Re: rancho?
Thanks for the reply, and I will be doing the same stuff that they have at the hummer dealer course, and i have search through past entries and most of them are 2006 so if any of you own one please help thanks
