Old 08-03-2007, 02:19 PM
bonzaiii bonzaiii is offline
bonzaiii is on a distinguished road
Default Removing interior trim
I'm installing some rear marker lights and I need some help getting the inside piece of the tailgate on my H3 removed.
I have removed the black inner portion of the tailgate (Where the jack goes) but cannot figure out how to remove the upper portion around the window.
Any help would be appreciated.
Old 08-03-2007, 03:31 PM
SR1355's Avatar
SR1355 SR1355 is offline
Default Re: Removing interior trim
Give it a good hard pull starting at the bottom edge. The clips really hold it in place, you may need to straigten a few clips once you have it removed.
Paul M
SR1355
Old 09-13-2007, 05:02 PM
subunix's Avatar
subunix subunix is offline
subunix is on a distinguished road
The best way ive found is to pull a little on the trim panel and take something flat and push one side of each of the clips and it should pop right out, ive seen a million break when you just try and yank it out
"We don't do pretty"
