Old 08-05-2007, 09:23 PM
datapimp69's Avatar
datapimp69 datapimp69 is offline
datapimp69 is on a distinguished road
Default Random/Multiple Cylinder Misfire Detected
well my H2 has just started throwing this code.
when i am at WOT, it does surge or hesatate, the tach does go up and down.
i do have a super charger on it and a borla exhaust.
anyone else have this problem.
oh... i have been trying diffrent brands of gas since this started to see if i was getting some bad gas.
Old 08-05-2007, 09:39 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Random/Multiple Cylinder Misfire Detected
Likely have A restricted cat converter. Check backpressure of both if either is over 1 psi of backpressure that will cause random missfires on that bank.
Old 08-06-2007, 05:10 PM
H2 Bill H2 Bill is offline
HUMTECH is right (as usual!). I had the same thing happen last week. I got the same code and have been getting a code for a bad passenger side converter too. It happened when going up a steep incline and punching it hard and the check engine light kept blinking on and off. I downloaded (if I remember correctly) code P101. I have a supercharger also.
1994 Chev Suburban Blown
Old 08-08-2007, 06:09 PM
datapimp69's Avatar
i forgot to mention that i had high flow cats installed. there is allmost nothing in there and cant see how it would make any back pressure but i will check it
Old 08-08-2007, 09:50 PM
Where in the world did you find hi-flow cats for the H2?
Old 08-09-2007, 12:53 AM
datapimp69's Avatar
just find the right size and put them on.
here is what i bought
http://store.summitracing.com/partdetail.asp?autofilter=1&part=DTC%2D79%2D400250 &N=700+0&autoview=sku
Old 08-09-2007, 01:15 AM
IRA51's Avatar
IRA51 IRA51 is offline
what code # is it throwing ? on a side note you could have gotten the Random tecnoligy cat to fit in the H2 without any problem ,and I hear they claim to be the freest flowing.
A government big enough to
you have.
-- Thomas Jefferson
Old 08-11-2007, 11:28 PM
HUMTECH's Avatar
Ummm well the stock converters when working properly have less than 1psi backpressure, hard to get much flow increase over that.
Old 08-13-2007, 06:47 PM
At first I got the po420, I replaced the driver side cat and then got the po430 and replaced the passenger side. No codes since.
Old 08-13-2007, 11:40 PM
IRA51's Avatar
have you checked to see if the headers havent burned the plug wires? old cheap skates way to check plug wires . get a spray bottle and spay the plug wires a night and start the truck if you see sparks the wires are shot . a DVOM will also work no water needed.
you have.
-- Thomas Jefferson
