Old 08-14-2007, 05:58 PM
jebia jebia is offline
jebia is off the scale
Default Noisy Nav unit
the Factory Nav unit on my 2005 H2 keeps making noise when the Nav CD is inserted. The unit works fine (displays map), but the unit makes a noise like the hard drive is continually accessing the nav disc.
Is this normal, or is it supposed to be quite.
thanks in advance
Jon
Albuquerque, NM
Old 08-14-2007, 06:57 PM
Microday's Avatar
Microday Microday is offline
Microday is an unknown quantity at this point
Default Re: Noisy Nav unit
This is what GM calls normal. I had one complete Nav unit replaced because of the noise issue and one unit that was considered acceptable.
Any interior noise or rattle is an immediate distraction for me......turn your radio up!
had '05 H2 SUT, LUX, Desert Sand
Had '05 Desert Sand H2 LUX
Had '05 Red Metallic H2 ADV
Old 08-14-2007, 08:02 PM
marin8703's Avatar
thanks in advance
Jon
Albuquerque, NM
theres a hard drive in the factory nav unit?
Old 08-14-2007, 09:27 PM
Thanks, I'll run it by the service advisor, its worth a shot.
Sorry, I meant "CD drive", not "hard drive".
Jon
Albuquerque
Old 08-14-2007, 09:34 PM
You can probably hear something going on in the unit when you open your door to get in, without even putting the key in the ignition.
I had one replaced because a fan in the unit was running all the time and drained the battery.
Old 08-15-2007, 05:16 AM
finall finall is offline
Mine is noisy also. Dealer tells me this is normal. Sounds like crap.
Cheap SUV. He says, what do you want....
Old 08-15-2007, 08:26 PM
should be very quiet....
