Old 08-17-2007, 03:42 PM
410225 410225 is offline
410225 is on a distinguished road
Default PIAA 510 for DRL
Has anyone converted the H2 DRL to PIAA DRL into the bumper opening?
if so, how did you mount these to the existing opening since these and OEMs are different mounting system?
Old 08-17-2007, 05:09 PM
twenty2's Avatar
twenty2 twenty2 is offline
Default Re: PIAA 510 for DRL
I Did... I did!! I've got the PIAA 510's in. I'll try to take pics this weekend. I ended up turning the bracket around on the PIAA mounts and then placing washers in the back of the unit so it wouldn't bounce all over the place.
Old 08-17-2007, 06:30 PM
Cool! Thanks. I am anxious to see the pics since I am buying either the 510 if it fits in the DRL location or 580 on the brushguard.
Old 08-21-2007, 06:50 AM
twenty2's Avatar
see if this works for you.
Old 08-21-2007, 03:00 PM
Thanks. Any issues with aiming the light? I know the OEM DRLs are attached with two screws and I do not believe they are aimable.
Old 08-21-2007, 03:31 PM
twenty2's Avatar
No problems aiming. I aim mine just below the headlight beam. (gotta do that at night) so I don't blind anyone. On the PIAA bracket, there are 2 bolts to loosen to do adjustments to aim up & down.
