Old 08-22-2007, 10:02 PM
(((echo)))'s Avatar
(((echo))) (((echo))) is offline
(((echo))) is on a distinguished road
Default Tire upgrade??
Sorry if it has been posted allready but was curious as to how big a tire can i go with without lifting the beast.
I'm pretty sure 35's will fit but what about 44's
Old 08-22-2007, 10:27 PM
IRA51's Avatar
IRA51 IRA51 is offline
Default Re: Tire upgrade??
37-13.50x17 will rub just a touch at full turn,and if you have air ride you will need to modify the level sensor arms in the rear .35-12.50x17 no problem . 44 ain't happening without a lift.
A government big enough to
you have.
-- Thomas Jefferson
Old 08-22-2007, 10:55 PM
I don't know about upgrading from a stock 34.99999" tires to the 35's...
Could be trouble
Put your 44s on a '72 Bronco with a 18" lift and forget about destroying the value of your H2....
1968 Mustang GT convertible
Old 08-22-2007, 11:44 PM
IRA51's Avatar
brushing up on your sarcasiom I see .
you have.
-- Thomas Jefferson
