Old 08-23-2007, 12:15 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
Default Update on sub/amp install
I posted in the other thread about this, I had recently installed a sub/amp to the existing stock bose system. I tapped the rear speakers with a line out converter for the amp signal.... It seemed it was not getting the really low bass, after messing with it and swapping different amps/subs in with no results I ordered a PAC interface model: AOEM-GM24
The sound is 100 times better, getting a unmolested signal from the back of the head unit makes all of the difference in the world, the sound is simply amazing. I moved the RCA wires up front, fished them up the the HU/interface, pulled the HU and wired in the Nucleus ipod integration, played with the gain and x-over settings and had the whole thing wrapped up in about 45 minutes. Getting to the back of the head unit is a breeze in this thing and the ipod interface took less than 10 minutes to install. If you like music..... this is a must do
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
