Old 08-28-2007, 12:35 AM
Groundpounder Groundpounder is offline
Groundpounder is on a distinguished road
Exclamation Fuse box
I have often installed things on my vehicle, however, I have never had it cost me. I recently purchased the lower grill with the off-road lights. I got the grill and bumper off, removed the old lower grill, installed the new one and put everything back with no problems. Next I started doing the wireing harness. All went well unitl I recached the part where I had to remove the fuse box and install an adapter and two wires. That part went OK, then I tried to put it back together. No go! I tried again, and again. I looked under the fuse box and fround one bent tab. Fixed that and tried again. I lost count how many tries but it finely went back into place. I connected the battery, got in, put in the key and nothing. All I got was a door ding and the front headlights came on. NOTHING ELSE. The key would not come out.
I learned that all wheel drive can be drug a few feet, to get it out of the garage, without any problems. I contacted OnStar first and they ordered a wecker - 5 hours later he arrived. I just had him get it out of the garage because it was to late to take it to the dealer. The next morning I called AAA and had to wait only 45 minutes for them.
End result - cracked fuse box. Cost $870.55. I do not think I'll mess with wiring for a while.
2006 Slate Blue Metallic H3, FlowMaster exhaust, True Flow cold air intake system, Ground Force rear lowering kit, custom locking fuel door, chrome hood grill w/handle, US Speedo gauge kit (chrome and red numbers), Custom rear tire cover, chrome tail light guard, custom paint on skid plate, new pin stripping, USMC front license plate. Semper Fi
Old 08-28-2007, 12:39 AM
tower's Avatar
tower tower is offline
Default Re: Fuse box
Bummer!
Old 08-28-2007, 08:14 PM
trailerpup's Avatar
I was having trouble too, when I installed my lights. I found that the clips or "jaws" on the 2 large connectors in the bottom of the fuse box must be in the upright position so the upper half of the fuse box will seat properly. I know this doesn't help you out here, but maybe it will help some of the other members. Good luck with your fix.
Old 08-30-2007, 12:37 AM
That box looks tough enough. However looks can deceive. Sounds like wiring should be kept above board.
